Old 5th July 2007, 03:06 PM   #1
Send a message via ICQ to KozmoNaut Send a message via MSN to KozmoNaut Send a message via Yahoo to KozmoNaut
Question Jamo 23503 8" drivers
Having recently replaced my Jamo satellites and subwoofer with a proper set of floorstanders (Audiovector C2 MK2), I'm left wondering what to do with the Jamo sub.
It's rather battered and worn-looking (the beautiful smoked glass plate on the top was destroyed by a falling vase a few years ago), but it hasn't been abused sound-wise.
It's an isobaric 4th order bandpass sub with two 8" drivers.
So I would like to ask if anyone has even the slightest idea of what the T/S parameters for such units could be, and if they could be used to build a better sub than the "I have a huge hump at 60hz and that's it" Jamo sub.
Preferably something that integrates properly with the Audiovectors. They reach down to 40hz or so.
The name of the drivers is "Jamo 23503" and they are roughly 10 years old. The sub is an SW 200-II, in case that helps.
I've searched here and on Google and found nothing of use, but perhaps someone here has an idea.
Old 7th July 2007, 10:09 AM   #2
I've attached a (crude) drawing of the outside measurements and the size of the port.
Based on this, would it even be slightly realistic to construct a sub that reaches to 25hz or so using those two 8" units?
Or would I be much better off spending ~$100 on a single 10" or 12"?
Old 7th July 2007, 02:55 PM   #3
GM is offline GM  United States
GM's Avatar
Greets!
Without specs the only thing I know to do is construct a low tuned cab known to be too large and damp it as required, but it will be relatively huge/low WAF and probably cost >$100 just for the plywood..........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th July 2007, 02:33 AM   #4
That's what I was beginning to think...
Oh well, no reason to tear apart a perfectly usable piece of equipment to make something worse. I'll just have to find a good sub-$150 unit an build something with that.
Any good suggestions for a good 12" driver or perhaps 2 10" drivers?
I am seriously considering building an EAS-based sub since I might be able to lay my hands on a good 500watt class-D amp, and I'm pretty good with electronics, so the EAS circuit should be no problem.
Living in Denmark, my best choices would probably be Scanspeak, Vifa, Peerless and Monacor. Do any of them have a good driver for EAS that you know of?
Old 10th July 2007, 01:44 AM   #5
GM's Avatar
I don't keep up with the 'latest and greatest' sub drivers, especially the European ones, so start a new thread to get some useful recommendations from those that do.
Old 10th July 2007, 02:21 AM   #6
OzMikeH is offline OzMikeH  Australia
Buy a tin of paint and dress up the old sub, sell it and turn the money toward your new one.
Have a look at the Rythmik sub kit thread, they are bit expensive with amp and driver for $500 US but excellent sound quality for the price.
They do an EAS style equalization module for them.
For incredibly high WAF find an ornamental chest with legs, cut a hole in the bottom, put your ugly unpainted particle board sub woofer box inside. Let her fill the rest of the space in the chest with blankets and sheets.
Old 10th July 2007, 08:37 AM   #7
I'll look into the Rhythmik kit, thanks for the tip :-)
And thanks for your help too, GM :-)
what drivers used in Jamo r909? Kickin Wing Multi-Way 13 4th November 2009 07:36 AM
t/s for 15" from jamo d365 HELP wingman Multi-Way 3 24th November 2008 02:48 PM
WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. Spasticteapot Swap Meet 1 5th November 2006 03:31 PM
Quick response needed - Anyone know anything about JAMO FR drivers? Spasticteapot Full Range 0 19th October 2006 09:05 PM
Info on "Jamo Dynamic d2e" speakers required John Biles Multi-Way 5 5th August 2005 07:02 AM
Page generated in 0.08558 seconds (75.37% PHP - 24.63% MySQL) with 11 queries
