Hi, I'm just about to start my second subwoofer project.
I'd like to try a tube this time. I've forund a supplier of cardboard/particle board tubes but I'm not sure what to order. Is there a minimun wall thickness required for a tube of 450mm diametre? Also is internal bracing needed with a tube? My plan is to build a pair of 450mm tubes 750mm in length, each with a pair of 65mm pvc ports and a single 12" Monolith driver. Driver specs are here http://www.bkelec.com/HiFi/drive_uni...onolith_du.htm Rich.
I learn something old every day. |
#2 |
Did it Himself
There is somebody in Bristol trying to sell exactly the tubes you are after. He got a few made up for himself and now has some spare. I think he was offering them at a good price.
Can't remember his username though... you could try a search on "sonotube".
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 | |
Uk supplier is http://www.essextubes.com/index.php?page=industrial but they have yet to confirm delivery cost.
#5 |
Thanks for that. Re your query about wall thickness - I have a set of cardboard tubes, 150mm diameter with 10mm wall thickness and these are very rigid. For the sort of use your talking about, I'd have thought 10 - 15mm would be fine.
I'll contact Essex and see if they deal with any builder's merchants nearby. |
#6 |
These cardboard tubes are used to mold concrete columns and are very strong. The forces are evenly distributed all the way around the tube. If you were building a sealed tube you would have more trouble with your end caps then the tube. My tube sub is like the Bose acoustic wave cannon only it's 16" diameter and I used 2 18" woofers in a face to face push pull arrangement 3' into a 12' pipe. Total cost not including the amp was under $250US and it is the most articulate & deep sub I have ever heard.
#7 | |
18" drivers in a 16" tube, how does that work? Got a picture? Rich.
#8 |
The 18" is the outside measurement and the back side was just a hair bigger than the tube. I made 2" slits all around the sonotube and forced it onto the back side then sealed it with something similar to dynamat.
I am building a new one and will use Mach5 MJ18's this time, they will have greater Xmax and should have less surround noise at high output. |
#9 |
#10 |
Ok, now i get ya.
Are both ends of the tube open or just one? This could be something I try behind my sofa........mmmmm, the possibilities!
| subwoofers | chuchu31642 | Car Audio | 1 | 8th July 2008 05:30 AM |
| Subwoofers | BEAN27 | Subwoofers | 5 | 23rd April 2006 09:09 PM |
| New subwoofers | postman | Subwoofers | 30 | 14th December 2005 02:33 AM |
| Need help with my subwoofers... | yesgrey3 | Subwoofers | 0 | 5th August 2004 05:48 PM |
| Page generated in 0.12141 seconds (77.53% PHP - 22.47% MySQL) with 10 queries |
