Hi ! I would like to build a sealed subwoofer based on the 12" Peerless 830847 in a 80 litre box. I have trouble finding subwoofer plate amps here. Therefore i would like to power the sub using other means. Can i use gainclone amp or hypex ucd amps to power the sub since these are available where i live ? I am also not sure how much power this subwoofer would require. Any advise would be very helpful.
#2 |
Did it Himself
A gainclone will not be suitable IMO.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
That means i need to use hypex ucd amps ? Should i use 180w or 400w amp ?
#4 | |
Your sub needs only an amplifier that is stable with a load of 2 Ohm; maybe 2 paralleled 3886 would be adequate. See Picture. b 1(1) |
#5 |
Is there any unit of measure or something that can tell me how the bass of the designed subwoofer will sound like ( tight or loose )
#6 | |
Buzzy,
I don’t think you can bargain for a better-designed woofer (the volume chosen) with this driver, as it’s in my opinion quite optimal if you are primarily concerned with possible sound quality. Of course there are always tradeoffs once the Qtc is chosen as you find the Qtc often is chosen within the span of 0.5 and 0.7. By choosing and with a value of Qtc= 0.6, you’ve landed between an optimal critical damped or transient perfect (0.5 is loose and often considered too over damped) and possible tightest sounding alignment (too warm if over 0.7 and between 1) i.e. very near at a Bessel response (= 1/sqrt (3) or about 0.577) which is the alignment with has the lowest and flattest group delay. Good reading of this subject: http://www.geocities.com/kreskovs/Box-Q.html b |
#7 |
Thankz bjorno, that article was very informative. I seem to have a problem with exceeding cone excursion if i input more than 10 W of power. Did i make a mistake ? I used winisd alpha 0.50a7 to simulate this.
#8 | |
Hi Buzzy, No, probably not, but I did.Sorry, I forgot to adjust all values to a 2.5 Ohm load instead of into a 8 Ohm load that all MJK: s programs are referring to. I recalculated all and you can check if my calculations seem correct, the last two submitted pictures. b 1(3) |
#9 |
2(2)
#10 |
3(3)
| subwoofer under bed | Potato42 | Subwoofers | 7 | 13th January 2009 02:21 PM |
| subwoofer project, which subwoofer? | Davlaf | Subwoofers | 12 | 9th November 2006 03:59 AM |
| Subwoofer crossover / subwoofer module design | derMichi | Subwoofers | 4 | 20th April 2006 10:31 AM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 03:19 PM |
| I need help with subwoofer deisign: HUGE inexpensive subwoofer | hottyson | Subwoofers | 16 | 4th May 2004 03:51 AM |
| Page generated in 0.12286 seconds (74.08% PHP - 25.92% MySQL) with 11 queries |
