Old 12th June 2007, 05:59 AM   #11
frugal-phile(tm)
planet10's Avatar
Default Re: Design Challenge #1
Originally posted by kgillies
dual 10" Peerless drivers
Do you have a model number?
front firing from a 8.5"h x 27.5"w x 8.5"d (all dimensions ID) enclosure, which ports out the back left side to a 8.5"h x 40.5"w x 8.5"d enclosure which in turn is ported through a 7.5"w x 8.5"h opening on the back right side into a 8.5"h x 12.5"w x 8.5"d enclosure that finally ports out to the front through a 4.5"w x 8.5"h opening!
Can you post a sketch? I'm having trouble visualizing this (and isn't 8.6" a tight fit for as 10" driver?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th June 2007, 06:22 AM   #12
terry j is offline terry j  Australia
maybe if you don't have a model number a photo will help people ID it
Old 13th June 2007, 03:20 PM   #13
Speakerholic
Cal Weldon's Avatar
Default Re: Drivers
I believe the Peerless drivers are 8 ohms - they aren't labeled.
Use a multimeter to measure the DC resistance. It will read approx 6 ohms for an 8 ohm driver and around 3 for a 4 ohm.
[i]Anyway, the question is with that amp am I better off running the drivers at 4 ohms or 8? [/B]
If they are 8 ohms, your choices are 4 or 16 ohms. I would run them in parallel for 4 ohms. If they are 4 ohms, wire them in series for 8 ohms.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Design Challenge #2 kgillies Subwoofers 3 12th June 2007 06:05 AM
The under $100 challenge cotdt Multi-Way 60 13th March 2006 06:11 PM
Power supply design challenge! dfdye Chip Amps 23 20th February 2006 07:06 AM
Speaker design challenge: 105db 20 - 20k at listening position paulspencer Multi-Way 28 9th July 2005 10:12 AM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
Page generated in 0.06803 seconds (70.11% PHP - 29.89% MySQL) with 10 queries
