Old 6th June 2007, 06:02 PM   #1
Default Servo vs. Linkwitz
Okay, I'm going a little nuts trying to decide between two possible 12" subwoofer designs and I was hoping that I could get some advice....
The first design is a 2 Ft sealed box with a Dayton RSS315HF, a 500 watt BASH amp and a Linkwitz transform. If WinISD's predictions are correct this will have a -3dB at 21 Hz. (How accurate is WinISD's Linkwitz modeling anyway?) At peak power it will produce around 108 dB at 20 Hz.
The second design is the 12" servo based system from Rythmik audio in a similar 2 Ft sealed box which, from what I've read, can have an -3dB somewhere around 14 Hz but generally outputs less dB. Plus, since it is a servo, it will theoretically provide lower distortion and flatter response.
The sub will be used almost exclusively with music and will be integrated with a pair of Rega R5s... I haven't decided on the crossover point but probably somewhere around 60 Hz.
I'm leaning towards the Rythmik based on the promise of lower distortion but I have to admit that the promise of the servo is almost a little too good to be true.
Thanks for any advice!
Old 6th June 2007, 07:34 PM   #2
RobWells's Avatar
Both servo subs I've demo'd sounded excellent - A lot cleaner than most non servo subs I've heard. Should work very well with a music system.
Rob.
Paradigm servo 15,
Martin Logan Descent btw.
Old 6th June 2007, 08:30 PM   #3
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
well if you were going to do a L-T sub, wouldn't you start by making it significantly smaller than the alternatives?
Matt
Beyond the Linkwitz ASP cuibono Multi-Way 24 12th November 2008 07:30 PM
Linkwitz sub heinz1964 Subwoofers 7 1st October 2007 07:09 PM
Who has done Linkwitz's microphone mod? The Paulinator Multi-Way 11 28th August 2006 01:05 PM
Linkwitz Transform PCB? diydave Parts 2 1st September 2005 12:05 AM
Linkwitz Sounds CD Bose(o) Multi-Way 0 26th July 2005 11:44 PM
Page generated in 0.07632 seconds (75.90% PHP - 24.10% MySQL) with 10 queries
