I am trying to build my first subwoofer. I have got a 300+ watt (rms at 4 ohm) plate amp and a TC sounds 1000 12" driver.
http://www.tcsounds.com/tc1000.htm But I might have made a mistake when perchasing the driver. It is a dual 4 ohm voice coil. I know I should find another 2-channel power amp to work with this driver to meet the specs. But I wonder if I can still use the plate amp drive the dual coil driver since it is already there. And how to connect them? Thanks in advance. |
#2 |
Speakerholic
You can still do it. If your amp is stable at 2 ohms, wire the coils in parallel. If not wire them in series.
#3 |
Well, my suggestion is if you're not sure your amp can work stable at 2ohms loaded, just wire your bass driver units in series.
#4 |
What do you think KG-5230 plate amp?
http://www.madisound.com/catalog/pro...roducts_id=371 Can it handle 2 ohm? |
#5 |
From the looks of it no, it cannot handle 2-ohms. Just wire it in series for a total of 8-ohms, which is within the recommended impedence range.
#6 |
Speakerholic
Agreed.
#7 |
I have an old M&K V2-B 12" sealed sub that blew its circuit board. M&K went under in February while holding my circuit board for repairs. Great timing, eh?
So, I found a vendor (ApexJr.) who picked up some surplus M&K sub amps (with higher wattage than the original), and I bought one. Once I started to test the amp before installing it, I realized that the woofer is a dual voice coil. Incidentally, I hooked up the leads to one (side?) of the woofer and tested it to be sure I hadn't blown the woofer. It pushed fine, so I'm happy about that. My question: since my amp only has one set of leads, is it bad/wrong/ill-advised to just hook up the single +/- leads to the woofer? What are the other options? Are there DVC amps, or just two amps for a DVD? Help! As far as I can tell, my original M&K amp appeared to have two sets of leads rather than two discrete amps. Sorry I'm so dumb, but I could really use some help so I don't destroy what's left of a great old subwoofer. Thanks, Phil |
| newby phase question | b1gn1g3 | Full Range | 3 | 4th September 2008 02:51 PM |
| Newby question Peerless XLS12 designs | Glen1 | Subwoofers | 5 | 22nd November 2005 07:23 PM |
| Newby Esp P67 Question Help Pls! | led_zeppelin | Solid State | 0 | 7th October 2004 12:02 PM |
| Dual voice coil wiring question | bigshooter13 | Multi-Way | 18 | 4th October 2003 09:18 AM |
| Page generated in 0.09477 seconds (80.31% PHP - 19.69% MySQL) with 10 queries |
