I am having a bit of an issue, regarding the "proper use" of DVC woofers, and I was hoping somebody might have contact information for Mr. Vance Dickason. I am trying to get as much input from as many people as I possibly can.
I have already gotten results from Dan Wiggins (of Adire Audio), Tom Bohlender (of Wisdom Audio), Thilo (of TCSounds), and two (personal friends of mine) loudspeaker engineers from Harman, in Northridge, CA, who asked to remain nameless. So far, everything seems to be leaning toward my point of view, but I have ONE person in my argument, who has suddenly thrown Mr. Dickason's name into the mix. I'd simply like to get his opinion, now. For those of you interested in the argument, here it is. I have not, as of yet, posted complete input results from the above mentioned names, although my posts have both been based on responses from Dan Wiggins, and my driver engineer friends from Harman. |
#2 |
Vance Dickason can be contacted at vdc@northwest.com
#3 |
Thankie!
~~Muchly appreciated~~ |
#4 |
#5 |
Did it Himself
The answer is quite simple. By only using one coil you simply halve the efficiency and reduce somewhat the thermal power capacity of the drive unit. Thiele-Small parameters remain the same as if the coils were driven series or parallel.
However, you can fiddle with the Thiele-Small parameters by adding resistance across the undriven coil.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
Speakerholic
It seems a bit of a moot point. If you don't intend to use both coils, why use that woofer?
#7 |
I was wondering if anybody actually read the thread I linked to... Seems everybody was willing to offer up suggestions, regarding why one should or shouldn't do it, (mostly "shouldn't", but if anyone had read the thread I linked to, they would have known that there were VERY valid and solid arguments as to why it is perfectly acceptable to run only one coil...) but all I was asking for was a way to contact Mr. Dickason.
I got the contact information I asked for, and I will soon be (hopefully) receiving a reply from Mr. Dickason, and I will place that reply on the12volt. |
#8 |
You can run them in parallel (if your amp can handle it), in series, using only one voice-coil or even running both voice-coils using different channels (a mate used to run his Tumult like that).
richie00boy mentioned in his post what the ramifications are. What you actually do it up to you. "There is no should, or should not. There is only do, or do not." (apologies to master Yoda)
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
| Vance Dickason Studio Monitors | Gargoyle | Multi-Way | 3 | 27th May 2005 06:58 PM |
| LPG Website / Contact Information | 10K2HVN | Multi-Way | 2 | 20th March 2005 04:12 AM |
| Anyone have LCY contact information? | mbcouple | Multi-Way | 3 | 18th March 2005 02:15 PM |
| Added Vance Dickason and AndyG to the gurus. . . | Pjay | Multi-Way | 1 | 11th March 2005 11:14 AM |
| Vance Dickason HT Kit | joek | Multi-Way | 5 | 20th December 2003 02:19 PM |
| Page generated in 0.10686 seconds (72.33% PHP - 27.67% MySQL) with 10 queries |
