Old 3rd June 2007, 04:16 PM   #1
epalla is offline epalla  United States
Default highest output from two smaller subwoofers?
I have two small (8") subwoofers available that I've taken off a friend's hands and I was wondering what the best cabinet would be to get a lot of output from them. I'm just looking to make a party sub here so I don't care for fidelity nearly as much as pure output. I know it's not an ideal situation, but I got them for free and cabinets are fun to build so I figured I'd give it a shot and see if I can get anything out of it. I've looked at horns, push/pull, plain ol' vents, etc. and I don't really know how to choose.
Any ideas?
Old 3rd June 2007, 05:05 PM   #2
Do you have any specs? What brand?
Without it its hard to say anything about it.
We live in a horizontal world, why use vertical topologies???
Old 3rd June 2007, 05:31 PM   #3
Hard to tell exactly, they're early Rockford Fosgate Punch subs and I don't see a specific model number on them anywhere. I think this is about right though:
* Nominal Impedance: 4 Ohm / 8 Ohm
* Power Handling: 100 Watts
* Peak Power: 200 Watts
* Sensitivity: 88dB / 88dB
* FS: 44 / 46 Hz QTS: .37 / .38
* VAS: .67 cu. ft. (19.0L)
* XMAX: 0.19"
* Voice Coil Diameter: 1 ˝"
* Mounting Depth: 3 11/16" (93.7mm)
Old 3rd June 2007, 06:43 PM   #4
Did it Himself
richie00boy's Avatar
They will be best in a vented box, start with 20 litres as a ballpark.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th June 2007, 01:47 AM   #5
is it that cut and dry? I was hoping something fancy out there could do better than the pure vented box.
Old 4th June 2007, 08:27 AM   #6
Did it Himself
If your primary goal is output over quality, a bandpass box would be worth looking into.
Old 4th June 2007, 10:28 AM   #7
Hi, Quantity over quality, 2 drivers shown, /sreten.
Old 6th June 2007, 02:48 AM   #8
What changes in the box design if I want to make a single cabinet? I can share the center port and have the drivers face each other, yes? That doesn't mean I should double the volume/ports in the middle though does it?
Old 6th June 2007, 07:56 AM   #9
Hi, I do not understand what you are describing, /sreten.
Old 6th June 2007, 10:00 AM   #10
Did it Himself
I believe you want each driver in it's own rear chanber, firing into the same front chamber, so it's like a mirror image? In that case the front volume figure sreten has given you needs to be doubled, and you tune the front section to the frequency as given. That could be accomplished by one or two or even three ports, it depends what diameter pipe you use.
Highest quality Dip sockets? AudioX Chip Amps 1 11th June 2009 10:13 AM
What's the highest power amp you've built? esorcc Solid State 24 13th March 2009 10:26 PM
Highest Quality 2-way amirmk Multi-Way 52 23rd August 2005 10:01 PM
Need to get the highest voltage swing, which output topology? EWorkshop1708 Solid State 7 2nd March 2005 06:56 AM
Page generated in 0.10052 seconds (79.89% PHP - 20.11% MySQL) with 11 queries
