Old 6th June 2007, 10:19 AM   #11
Originally posted by richie00boy
I believe you want each driver in it's own rear chanber, firing into the same front chamber, so it's like a mirror image? In that case the front volume figure sreten has given you needs to be doubled, and you tune the front section to the frequency as given. That could be accomplished by one or two or even three ports, it depends what diameter pipe you use.
If the above is the case you need 3 15L chambers.
Two outside tuned to 33Hz, the centre one tuned to 80Hz.
/sreten.
Old 6th June 2007, 11:00 AM   #12
Did it Himself
richie00boy's Avatar
Surely you mean 3x 30 litre chambers.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th June 2007, 11:40 AM   #13
Hi, nope, the sim shown is for 2 drivers in a box, /sreten.
Old 6th June 2007, 12:20 PM   #14
Did it Himself
OK I thought it was for one.
Highest quality Dip sockets? AudioX Chip Amps 1 11th June 2009 10:13 AM
What's the highest power amp you've built? esorcc Solid State 24 13th March 2009 10:26 PM
Highest Quality 2-way amirmk Multi-Way 52 23rd August 2005 10:01 PM
Need to get the highest voltage swing, which output topology? EWorkshop1708 Solid State 7 2nd March 2005 06:56 AM
Page generated in 0.08490 seconds (63.61% PHP - 36.39% MySQL) with 11 queries
