#11 |
Thanks for the responses.
The driver is an Orion HCCA prototype, so I'm not sure if the T/S parameters are exact, but these are the numbers for the production one. ![]() The driver is meant more for spl applications, but it's what I have at the moment and I may swap it out or have it reconed with different softparts. @fullthrottle: This is why I'm glad is asked about this. I've never dealt with ht and I've only seen ported commercial subwoofers. I was also under the impression that sealed enclosures allow for greater power handling as there is no chance of unloading. I went with a large box as to compensate for the low wattage I was originally planning on running. @richie: Carpet over cement. @paulspencer: I had run the numbers in an online calculator before buying the port and got around 17" port length for a 4"diameter port in a 4cubes box @ 20hz. It has flared ends, but I'm not usre if this is enough area to prevent chuffing. @marzen: Front stage is a pair of Andy Graddon's 1/4wave tapered pipes. |
#12 |
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| PSU for QSC amp questions | rkc7 | Parts | 5 | 10th November 2005 05:18 PM |
| Last questions about this | Madmike2 | Multi-Way | 9 | 13th June 2005 11:12 PM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.06695 seconds (70.10% PHP - 29.90% MySQL) with 10 queries |
