I have a couple of q's about these boxes,
for a short background i have a Illusion audio nd-15 fs of 25hz 1st question - Can i tune the box to 25 hz 2nd- 1127/25 = 45 and 1/4 of that is 11ft, when i build the tunnels that long do i have to add a chamber for the sub, 3rd and last for now, with the port size affect the tuning. Thanks Dan |
#2 |
I found this at http://geocities.com/rbrines1/Pages/...nt_Pipes.html,
"The first TL example is a "Rule of Thumb" TL. The length of the pipe is 1/4 wave-length at fs. The wide end area is 2*Sd and the small end area is Sd" What do they mean by the wide end area is 2*Sd and the small end area is SD, is that refering to the end and beginning of the tunnel? |
#3 | |
2, not in a traditional TL, the sub is in the line it's self. 3, a larger area line (up to a point) will increase output and have some effect on the overall response, but won't effect tuning. |
#4 | |
True, but that wasn't the question. Regardless, based on the minimal published specs, this driver's Qts is a bit low for a Fp = Fs TL, being much better suited for a much shorter, higher 100 Hz Fp, but is ~ideal for a proper 2:1 CR B@#$ Wave Cannon if a nominal ~16.7 - 50 Hz BW is acceptable. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| about transmission line | bigcatdairy | Multi-Way | 14 | 25th November 2011 07:46 AM |
| FS: JX 92S in Transmission line cab | t-head | Swap Meet | 6 | 8th April 2011 05:29 AM |
| line array + transmission line ? | zobsky | Multi-Way | 12 | 16th August 2006 04:18 PM |
| Transmission line box? | customsuburb | Subwoofers | 15 | 25th January 2005 11:35 PM |
| how to combine Line array and transmission line together | Jared | Multi-Way | 5 | 19th April 2004 10:32 PM |
| Page generated in 0.23681 seconds (26.76% PHP - 73.24% MySQL) with 10 queries |
