Old 29th May 2007, 07:27 PM   #1
Default high efficiency small sub
hello every body
i have a work in progress concerning a high efficiency system
i built one full range ribbon (250 hertz -20000 hertz) based on a design by francois demisniere, a French diy man
the sensibility is about 102 Db
(on the photo, it's the thing that doesn't look like a speaker)
i have still one to build
i am now looking for an high efficiency subwoofer (min 97 Db) able to rise 300, 400 hertz and go down to 20-30 in a small box
do you know any
thank you for your answer?
Julien
Old 29th May 2007, 07:33 PM   #2
Speakerholic
Cal Weldon's Avatar
Default Re: high efficiency small sub
do you know any
Hi Julien,
There's no such thing. You are asking too much. You will have to change your requirements. If you want 97 dB, small box you need a PA woofer. These will be good down to about 50-60 Hz with some EQing.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 29th May 2007, 09:02 PM   #3
Default thank you
thank you for the answer
i will investigate this point
and the photo is here
Old 29th May 2007, 10:17 PM   #4
Hi, do you have any link to that driver or any other information to share?
I may be interesting for me to build a couple too i think...
Old 30th May 2007, 01:11 AM   #5
Speakerholic
Cal Weldon's Avatar
Yes, more pictures of the ribbon would be nice. And the rest of the drivers we can see there. Good looking stuff.
Old 30th May 2007, 02:14 AM   #6
banana is offline banana  Hong Kong
Cal is right, this will be a miracle sub.
If you use seperate amplifier to drive the sub, high efficiency is not necessary. Thus you can apply Linkwitz Transform to make it go down to 30Hz in a small box.
Old 30th May 2007, 01:47 PM   #7
badman is offline badman  United States
Custom Title
badman's Avatar
Indeed, it's commonly called Hoffman's iron law. A speaker box can have 2 out of 3: efficiency, low frequency extension, and small box size.....
The ideal way around this is to go with an infinite baffle subwoofer setup, where another room acts as an enclosure. These are also sometimes done with the backwave firing outdoors.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 30th May 2007, 06:17 PM   #8
freddi is offline freddi  United States
freddi's Avatar
a 15" in a 6th order reflex with ~6dB boost from a underdamped 2nd order highpass filter ~1-1.07*fb might be one option --- in US, sometimes EV Interface A or B EQ boxes can be found on Ebay cheap
Old 31st May 2007, 03:43 AM   #9
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
why have a box. What about dipoles. I assume 2 15" woofers on an 18" wide baffle might work. Something like the Emience Alpha.
...still looking for the holy grail.
Old 31st May 2007, 11:38 AM   #10
el`Ol is offline el`Ol  Germany
Or a low-Qts low-FS driver with 6dB linearization.
http://http://www.audiocircle.com/ci...?topic=41297.0
The Alphas are more for huge baffles.
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
Full range and/or High Efficiency possible in small cabinet? Seraph Full Range 29 19th June 2007 01:13 AM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 4th September 2005 11:12 PM
High Efficiency, High Power Handling? Bogie Multi-Way 3 2nd July 2005 05:49 AM
Any options for small, high efficiency speakers? tennisets Multi-Way 14 16th March 2005 02:36 AM
Page generated in 0.10081 seconds (77.29% PHP - 22.71% MySQL) with 11 queries
