Old 18th May 2007, 01:20 PM   #1
Send a message via MSN to Wildcard26
Default Elemental Designs EHQS12 Driver..
ED has these for $25 then add shipping to that. I have read that they are fairly good drivers and other's have done some projects with some nice results. I want to use this driver with a Dayton 100 W plate amp from PE and use the dimensions 36"Hx16"Wx16"D with a 4" port (haven't calculated the tuning length yet). I want to do the driver and port down firing with about a 4" clearance from the ground and the whole thing tuned to about 23-25Hz. I do more music than movies. Has any one had any experience with this driver in projects and if so I would really like to learn about your experiences and your comments and suggestions for my build since it will be a while yet till I get the plate amp. Thank you in advance for your time and input.
Old 20th May 2007, 07:13 PM   #2
Send a message via MSN to xstephanx
You must first check if that driver is suitable for a downfiring configuration. I cannot remember the formula, but it is somewhere on the parts express website. Sorry i could not be of more help
although box size and tuning is dependant on the parameters of the driver, model it with a speaker modelling software before you start pulling dimensions and tunings out of the air.
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 21st May 2007, 11:12 AM   #3
Thanks, will do. I did some research and came across designs that used the driver down firing. One person even did the calculations and apparently it is good for this usage. According to the T/S parameters of this driver I found out that it can be tuned to about 23Hz without over excursion with 100W plate amp. Thanks for your input I really appreciate it.
Elemental Designs EHQS12 as a HT sub? santiu Subwoofers 45 27th December 2007 08:16 AM
Elemental Designs subwoofer build sn_85 Subwoofers 0 9th July 2007 06:09 AM
eD EHQS12 on sale for $25 Lothar34 Subwoofers 1 29th December 2006 02:40 AM
Designs with a full range and bass driver? swin1 Multi-Way 3 19th May 2006 10:58 PM
Page generated in 0.07652 seconds (73.58% PHP - 26.42% MySQL) with 10 queries
