Old 16th August 2007, 10:03 AM   #11
theAnonymous1's Avatar
Default Re: Re: Worth mentioning...
Originally posted by navin
one popular OB 15" woofer (Hawthorne's Augie 15) has a Qts 0.92!
That driver has a high Qts due to the fact it is intended to be mounted on a narrow flat baffle; not in a W, N, or H config.
To help quiet the pole piece "chuffing" of my 15" dipoles I simply cut off the dust caps. Even without the dust caps the pole piece never gets above room temp, so they don't need the forced cooling.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 16th August 2007, 03:29 PM   #12
ashok's Avatar
Has anyone tried a W dipole sub with two 10 inch drivers ?
Any point building one . Would it be able to play loud enough ( 105db)? I have two old Pioneer carbon fiber 10 ich woofers. I don't have any use for them. Q is about 0.5 and Fs is about 37 Hz.
AM
Old 16th August 2007, 10:31 PM   #13
Also note that the Dayton DVC 15" can be had for about the same money as the IB and you can use resistive loading on the second voice coil to adjust the Q and decide for yourself what sounds best to you.
mike
Old 16th August 2007, 10:48 PM   #14
Default if you afford...
the small additional price and minimal increase in size go with two peerless SLS 12 drivers.
moray james
Old 17th August 2007, 08:56 PM   #15
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
I built two M-frames with two Visaton W 250 in each. They are nice in a 5x4 m room for decent levels, but no way would they do 105 dB. And that´s four of them.
www.dipolplus.de
Old 17th August 2007, 09:59 PM   #16
tinitus is offline tinitus  Europe
105db sub ? are you sure you want that, if so I dont think its small dipole you want, but more like a BIG PA woofer with low Fs or maybe even better a line source sub
Old 17th August 2007, 10:39 PM   #17
10" pioneer ? it sounds like an ordinary woofer with small magnet, thus no sub driver, so its best suited as an ordinary midwoofer in 3way setup up to 300hz, ordinary dipole may be fine, just dont expect a lot of deep bass, for that you will need yet another woofer
H frame vs W frame dipole woofers rick57 Multi-Way 18 8th October 2011 04:58 PM
W-frame Dipole Construction Q weinstro Multi-Way 9 20th August 2007 03:31 PM
8" Drivers for a small U-Frame Tenson Multi-Way 11 7th January 2007 02:27 AM
H frame/ Dipole/U frame ???????? j.burtt Multi-Way 24 1st May 2006 03:50 AM
Dipole with 2 10" drivers DarkOne Multi-Way 76 14th July 2005 02:39 PM
Page generated in 0.08666 seconds (75.87% PHP - 24.13% MySQL) with 10 queries
