Old 12th May 2007, 12:08 PM   #1
Default Is this ¼ WL & fs loow Transmission Line realistic?
I’ve looked at t-linespeakers.org and see reference to Martin King's & Auspurger's computer models, am happy to learn one, before I do - is this ¼ WL goal realistic or in the ballpark ?
A 6 m 20 foot (running along the ceiling) line of Sonotube or equivalent, ie a TL with no taper, with ¼ WL = 14 Hz
- used with a driver of fs = 18 Hz (Peerless XLS 12”)
should with …….. EQ be able get flat down to between the ¼ WL & fs, ie 14 – 18 Hz?
Old 12th May 2007, 12:35 PM   #2
I should have said, rather than dB, the goals are "tightness" & depth
Old 12th May 2007, 11:38 PM   #3
MJL21193's Avatar
Hi.
Need the divers other specs for accurate modeling. If you post them I'd be willing to simulate (as I am intrigued by your idea). The thought of the line extending across the ceiling is different, that's for sure.
TL bass re-enforcement is an excellent way to increase response below Fs.
Edit: Sorry, read after I posted, driver is Peerless XLS. This driver is purpose built for passive radiator allingment, and will give inferior TL results. You should consider another driver for your idea.
Old 13th May 2007, 01:10 AM   #4
Martin,
The ceiling - I just looked around and thought - do a kind of el-pipo but using the longest room dimension. Higher ceilings make it less visually intrusive.
I’ve heard that the XLS is built for passive radiators; and also with it’s very low Q for small boxes in cars.
You may know Linkwitz chose it for it’s very low distortion at < 100 Hz, always EQed, in both dipoles (Phoenix & Orion) and sealed boxes (Thor).
Also GM suggests http://www.diyaudio.com/forums/showt...ht=#post772802 what sounds to me like a TL using XLS.
I thought in that case . . here are the TS, with a higher distortion but still lowish fs opion
What parameters are good for TL, and what are bad?
File Type: txt two peerless tl candidates.txt (205 Bytes, 14 views)
Old 13th May 2007, 02:11 AM   #5
MJL21193's Avatar
To be honet I've not tried this sub in a pipe this long. The resuts are different than they would be for a shorter, tapered line.
Below are the results for a line cross section 3 x Sd. First is the phase relationship between TL and infiite baffle the second is expected frequency response. Though there is a massive drop after 40Hz, there is clearly a 5dB gain over IB below this. If you can tolerate the poor step response (.02 second delay), it may not be a bad option.
Old 13th May 2007, 02:27 AM   #6
Martin,
Thanks for the info, then what parameters might be best for good step response with long or non tapered lines?
Old 13th May 2007, 02:39 AM   #7
GM is offline GM  United States
GM's Avatar
Greets!
My referenced alignments are MLTLs, big difference! An end loaded TL this long isn't a good plan, but an off-set driver (L*0.2541) one with a 12" effective diameter (113.1"^2) looks good with modest stuffing (0.3 lbs/ft^3) with no audible timing errors if XO'd around 70 - 80 Hz.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th May 2007, 02:55 AM   #8
MJL21193's Avatar
Martin,
Rick, not sure why you are calling me Martin. My name is John...
Originally posted by GM
Greets!
GM
GM, I agree it's not a good plan, just interesting to get that much gain below 40 Hz. Of course, 3 x Sd is quite a large pipe.
Old 13th May 2007, 03:06 AM   #9
GM,
XO'd around 70 - 80 Hz is fine
“but an off-set driver (L*0.2541) one with a 12" effective diameter (113.1"^2)”
What is L, and is that a triangular or round cross section?
Old 13th May 2007, 03:08 AM   #10
John
"not sure why you are calling me Martin. My name is..."
oops, thought you were Martin King . .
Your thoughts on TS?
Cheers
FS: JX 92S in Transmission line cab t-head Swap Meet 6 8th April 2011 05:29 AM
Transmission Line Help Fradbut Multi-Way 9 9th March 2009 08:03 PM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
Transmission Line for or against? DJ Sense Full Range 5 10th June 2006 08:35 AM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Page generated in 0.11109 seconds (79.50% PHP - 20.50% MySQL) with 11 queries
