I've been reading this article on transmission line enclosures and I think I want to give one a try. I cannot, however, find any information on how to model the cone excursion for a TL enclosure. Are there any rules for this?
I normally use Unibox for my modelling, if that provides any kind of useful tool. Can I approximate this with any of the pre-canned enclosures? |
#2 |
Hi.
What driver are you using, and what's it's Xmax? Generally speaking, a TL is not much different from a bass reflex, as far as the drivers excursion is concerned. Modeling with Unibox to check max excursion can be done by matching the box volume and port size. Martin King developed a simulation model specifically for TL's - this is the most accurate way to model response (and excursion). |
#3 |
I had an extra 8" Dayton DVC lying around from when they were on sale. I used one to make a passive PR sub and for some other experiments. I figured I'd make a TL sub (since I never made one before).
I read King's website. His sheets are no longer free so I figured I'd make a cheap and easy one first and if I liked it, then I'd get his sheets. |
#4 | |
frugal-phile(tm)
To model a TL use Martin King's software or at least the tables (they are free). The software will show you excursion (and lots of other stuff) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Hi Dave - would Bullock's TLBOXMOD be good nuff for ballpark estimate?
Freddy |
#6 | |
#7 | |
frugal-phile(tm)
dave
#8 |
Below are two plots, first is freq. response of a 90" TL with the line cross section start at 2 x Sd, and the end .5 x Sd. It's unstuffed and shows good bass response. Below that is woofer displacement (excursion).
#10 | |
| Cone Excursion | johnc124 | Subwoofers | 7 | 10th April 2009 02:45 AM |
| WinISD - Cone Excursion | Mutley666 | Subwoofers | 12 | 12th December 2005 02:14 AM |
| Calculating Cone Excursion in DCR Sub | elambert | Subwoofers | 1 | 15th October 2005 11:57 PM |
| calculating cone excursion? | Jim85IROC | Multi-Way | 11 | 3rd April 2004 08:41 AM |
| Peak cone excursion | Vikash | Multi-Way | 8 | 9th July 2003 06:21 PM |
| Page generated in 0.72400 seconds (11.82% PHP - 88.18% MySQL) with 11 queries |
