Old 16th May 2007, 08:13 AM   #11
tang band makes some really small woofers down to 5 1/4", but they're extremely inefficient.
if you want to get sub bass out of a small enclosure, one way to do it would be to just amplify the heck out of a small woofer that can take higher power.
you might want to look into 8" auto woofers. alot of those are designed to work as subs in small enclosures.
you can get decent bass out of small woofers if you drive them hard enough. i was surprised at just how much bass my little mission 2 ways could put out even with the ports plugged driven by my 100w reciever. i never push my system hard except that one time when a neighbor was being a pain.
if you had a nice 8", you could do alot better.
adire makes a 6 1/2" driver i've heard people talk about as being good for small subs. i think someone else had mentioned them here.
Old 13th July 2007, 07:15 PM   #12
Lindell is offline Lindell  Sweden
Ok, so I just placed on order for two Tang Band 6,5" woofers.
Looks like I'll go with a 15 liter box tuned to 38Hz. I'm using WinISD to get these figures. It will not play straight to 30Hz, but more like 35Hz -3db. Fair enough for the system.
The cabinet design will be something really crazy....
Old 21st July 2007, 03:04 AM   #13
AVWERK is offline AVWERK  United States
Originally posted by Dr.EM
Perhaps an electronically equalised design would fit the bill? Take a look here:
http://sound.westhost.com/project48.htm
Should reach 30Hz in your box size requirements and the cold amps can supply enough power to get it working well I reckon
This design is based on the principal that this particular woofer design has pushed the resonate point well above the actual crossover frequency and now your using the sloped circuit to pull everything back to flat below resonance (12db per octave speaker drop below f/s and 12db circuit att.)
This is a superior design IMO
This might not work properly with the peerless arrangement
David
Old 2nd August 2007, 12:01 AM   #14
Default teeny sub
I am going to build a .75 cu ft enclosure for 2 Mpyre 65X subs.
It wont be loud, max of 102dB but will still be above 90dB at 20hz and still around 80 at 10hz.
Nice and simple sealed system with an F3 of 35hz.
Old 2nd August 2007, 12:22 AM   #15
Speakerholic
Cal Weldon's Avatar
Glad you chose them. I'm interested in hearing what you think. I have mine in a PR system and am quite happy.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st August 2007, 01:19 PM   #16
ALFIrE is offline ALFIrE  Belgium
any progress with the w6-1139 minisubs?
Old 31st August 2007, 09:50 PM   #17
Default Small Sub
For the ultimate in small, why not try a ripole?Especially as amp power and eq isnt an issue.
38x38x17cm?
http://www.lautsprechershop.de/hifi/...i/ripol_en.htm
Nick
Real Engineers do it on a budget.....
Old 13th November 2007, 07:46 AM   #18
http://www.partsexpress.com/projects...aSub/index.cfm
Check this out as posible idea.
Old 13th November 2007, 04:16 PM   #19
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
kinda late in the game but if I were going to build a micro-sub with good performance that had to be semi-portable I'd:
Use Neodymium magnet drivers (like the TB 6.5 and others)
Use a small box with multiple drivers (small box means less need for bracing large panels)
Use a linkwitz-transform in addition to a nice compact Tripath TAA4100 based amp and switching power supply at 12 or 24V depending on the impedance.
If you want louder, just add pairs of drivers.
Noob's first build !!!! bereanbill Tubes / Valves 13 20th April 2009 10:15 PM
Help a noob build a ZV9 neil_kaye Pass Labs 63 15th March 2007 02:18 PM
Diy noob want to build monoblocks. christianlie Solid State 3 11th December 2006 08:57 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Page generated in 0.10993 seconds (77.62% PHP - 22.38% MySQL) with 10 queries
