I'm embarking upon a whole house audio project. This involves putting a ceiling mounted pair of speakers in each of several rooms in the house. My wife has agreed upon using Gallo Acoustics A'Diva's in a gloss white finish. Since this is not a serious listening system they seem ok for the job.
However they don't have ANY bottom end at all. Thus to supplement the Gallo's I'd like to add a dedicated sub-woofer at each speaker location. Each sub would be attic mounted between the rafters, vented into the room with a single port. My idea is to mount the Gallo's by hanging them from a stem style mount from above. Ideally have the stem drop through the port of the subwoofer. The goal is to have reasonable bottom end for moderate listening levels but without having the subs physically present in the rooms. I have some 8" drivers on hand that might be good candidates for the subwoofers. They were acquired from www.apexjr.com a while ago and were originally the low-end drivers from Mackie 824 powered monitors, which I quite admire. The specs on the woofers area s follows: Vifa P22WP-01 8" woofers OEM marked. Used in the Mackie 824 monitors. features: 30 oz. vented magnet, 35Hz - 4KHz, Mineral filled poly cone, butyl rubber surround, cast mannesium basket, 1.5" voice coil TS: Fs 29.5Hz, QMS 2.20, QES 0.31, QTS 0.27, Vas 77 l, Re 5.8 ohms, Sd 235 cm2, Rm 2.5, Bl 10.2, Md 29.5 g, Xmax 6 mm Where I need help is working out the design of a suitable cabinet to arrive at a bandpass enclosure with a single port. I used to have a copy of BassBox Pro but have misplaced the CD. Anyone here willing/able to advise or assist? Michael
Michael Graves |
#2 |
Alternatively, if you have a favorite software for enclosure design I'd be interesting knowing about that as well.
Michael
Michael Graves |
#3 |
guess your more for home audio so
some of the ppl on here said winisd and it is free linerteam google it first one it wont give u a complete box and all that but u can do tuning and tell u volume |
| I had an idea...maybe a brainstorm result..some neuroniuns re-started to work | destroyer X | Solid State | 35 | 8th June 2009 09:05 PM |
| 807 SE project started.... | JandG | Tubes / Valves | 2 | 12th May 2009 12:17 PM |
| I've started my first project... | Bigun | Full Range | 38 | 8th February 2009 01:15 AM |
| New project actually started ;) | inrank | Full Range | 6 | 23rd February 2008 04:36 PM |
| Started my first speaker project! | ALFIrE | Multi-Way | 18 | 23rd November 2004 11:57 AM |
| Page generated in 0.06724 seconds (75.53% PHP - 24.47% MySQL) with 10 queries |
