#31 | |
First day of new semester, second one. Out of six.. actualy im at school right now.. first day and I have 5 pages of homework in maths...
Depending on your house structural integrity.... may be a house thing too
Time is the best teacher; unfortunately, it kills all its students |
#32 | ||
If you have the same system up there, then at the rate you're going, you will finish a four year degree program in a year and a half!!
#33 |
Back home..
Well I have 4 semesters left, thats 60 weeks.. but yhea.. its crazy, like as an example, on thursdays I have 8 hours straight of electronics.. thats with a 50 minutes pause to eat...
#34 | |
I won't be experiencing them for a while. Good luck with your studies!kelticwizard, thanks for the kind words about SubSim, I appreciate it I see you're beginning to like the program. SubSim is back under development, but finding permanent work is first in my to-do list, of course. So development is slow, but steady.cheers, Isaac
Crossover/Subwoofer Simulator |
#35 | |
I was slow to "take" to the program, but once I got the idea, it all fell into place. Realistically, it is not like WinISD where a 2 minute warmup is all that is necessary. But it isn't that long to learn either The major thing that you have to get used to is the fact that when you "X" out of a dialog box that you just filled with parameters, the info is retained. In most programs, you need to click an box that says "OK" or else the information is lost. With this program, that is not necessary. I will be checking into Crossover Simulator soon as well. Lots of questions there. Believe me, I'll give you a holler if I need help. Good luck with your job search. If your contribution to this forum is any indication, the employer who hires you on will have done himself a great service indeed! |
#36 |
Yep, awsome work indeed. Its truly one of those "must have" apps.
Keep up the good work
#37 |
so, hum back to subject
The only way out of this is to actualy either have a large surface or a big x-max, I checked some 15's at 5mm xmax at a surplus store. I guess a 10" with a very large xmax (expensive) would do as good as a 15" with relativly low xmax (cheap), but the 10"'s distortion will be greater. and i get 2 of those for the price of one shiva, around 3 of those = to the price of 1 tempest with shipping and all They are 85$ cdn each, no taxes, i'll ask and see if i can borrow one to measure it. that will make me 2400 sqcm at 5 mm xmax what do you guys think? the problem may be the size of that thing.. but.... the sound would be good
#38 |
The trouble with 15's is that they tend to have very large Vas values, making huge boxes necessary to get to the same F3 that smaller drivers can deliver in smaller boxes.
Still, measure it anyway, you never know what might be in store. Inexpensive drivers from "off-brands" sometimes have Thiele-Small values that do not work out when placed in the box. Even good quality brands have variation from the stated specs, but at least have a tendency to deliver similar performance when placed in a box built for the stated specs. "Off-brands" frequently do not deliver when placed in a box built for stated specs. But if they let you try it-hey, what have you got to lose? Every speaker company started out small and unknown, after all. |
#39 |
I did this frequency plot from 0 to 100hz of that max 10"
Y axis is dB's, X axis is frequency and this isnt at 1w
#40 |
Having some trouble reading that chart.
It looks like the woofer is at 158 dB @ 70 Hz! |
| 6th Order Bandpass Subwoofer (rear & front chamber size?) | nickthevoice | Subwoofers | 12 | 8th February 2008 10:01 PM |
| WinISD pro to simulate 6th order bandpass subwoofer | christophorus | Subwoofers | 14 | 13th September 2006 12:58 PM |
| 4th order bandpass 4 way | the phantom | Multi-Way | 3 | 27th July 2005 06:28 AM |
| the isobarik 6th order bandpass transmission line folded horn subwoofer idea | Yoda | Subwoofers | 3 | 24th October 2001 03:00 PM |
| 6th-order Bandpass | BAM | Subwoofers | 1 | 24th September 2001 05:51 PM |
