Old 20th April 2007, 06:16 AM   #1
Question JBL Sub high level input only
Hi i just bought a secondhand JBL TLX CSS-SUB1 off Ebay and have discovered that it has high levl in only, is there an easy way to change that to accept a low level input from the sub out of my Denon AVR 3300?, or should i jus solder a couple of RCA's onto the board from where it looks like a socket should be for a different model.
Old 20th April 2007, 05:00 PM   #2
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Why?
Just use the high level, if you use low level, you won't create enough drive to drive the thing. You need to obtain the circuit diagram, or maybe you could try and connect an RCA into the volume pot. I'm not familiar with your sub and assume its got its own amp(Active)? If you take the case apart, locate the volume pot, usualy a pot has three legs(mono , 6 stereo), one in one out and one ground. Usually middle contains signal either in or out with one of the others being ground and in out.
Make sense?
Cheers Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 21st April 2007, 12:18 AM   #3
i was thinking something like that mike, yes it is active , i really only want to use it for home cinema and not hifi which is why i want line level input via my sub out on the amp,could i possibly impedance match it by using a transformewr passively?
Old 21st April 2007, 02:19 AM   #4
Foxx510 is offline Foxx510  Australia
I'm sure if you post some good photos of the circuit board some of the brains here could work out where a line level input could go. As you say it might just be a matter of soldering in the RCA sockets.
Old 21st April 2007, 09:28 PM   #5
mikee55's Avatar
Default Hello again
The input would be 2 resistors right at the input socket. Possibly one pair would be large in diameter suggesting high power handling, I had this on a car amp, the other pair normal size.
Get some pics to us.
Cheers Mike
Old 22nd April 2007, 03:04 AM   #6
ta everyone i'll take photos tonight and post them monday morning aussie time
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
UcD400 and high level sub input chrisb03 Class D 51 21st May 2007 12:20 PM
Sub-woofer high level input StalfoS Solid State 2 15th February 2007 11:00 PM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
High input level LM3886 amp ? bibster Chip Amps 2 13th October 2006 07:13 PM
Page generated in 0.07487 seconds (75.27% PHP - 24.73% MySQL) with 11 queries
