Old 19th April 2007, 02:51 PM   #1
Default Low Pass filter for sub?
I need a simple low pass filter/volume for a sub. I can solder if I can's buy economically. B&W 602's are good to about 48hz, gone by 40hz. If I could get down a bit more it would facilitate some of the mixing I do. No thump,thump stuff, I want clean "Smooth" low-end extension...
I have a pair of Bozak 12" and a pair of JBL K145's to experiment with. 'spect the Bozak(s) would be more suitable in optimally sized box.
comments/suggestion welcome!
Old 19th April 2007, 03:13 PM   #2
Did it Himself
richie00boy's Avatar
I believe your main speakers are vented, so you will need a 4th-order filter to suit, on your sub. Search for Sallen-Key filters, it's pretty straightforward.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 20th April 2007, 05:58 PM   #3
Richie is probably right, but the roll-off characteristic will almost certainly not be a clean Butterworth or other usable Q value.
I suggest you make an active crossover and put the new frequency at about 100Hz, maybe even a bit higher going towards 120Hz or even 150Hz.
Now feed the new crossover to the main amp and to the amp that will drive your sub.
I have a sub crossed at 150Hz at the moment and it is off about 3feet to the right of the right speaker. I never hear any signal coming from the sub. It always appears to come from near the central position. It seems to me that the harmonics of the bass signals are locating the image for me.
How do others find a sub works with high crossover frequencies?
Either centralised between the mains or offset or even under your seat!
regards Andrew T.
Old 21st April 2007, 08:59 AM   #4
Did it Himself
I have to disagree a little. You will be able to get a 4th-order slope that is a good enough match to the B&W speakers. I would also not cross as high as 150Hz, unless the sub was inbetween the main speakers. It becomes a lot more room and position dependent once you go higher than about 90Hz, also some sub drive units aren't good above 300Hz or so.
It seems you have been lucky Andrew and everything has worked out, but it might not for some people, IMO.
I also reckon that if you crossed at 100Hz with the B&W speakers you would have a very boomy response, I think you need to aim for around 60Hz as a start.
Old 24th April 2007, 01:10 PM   #5
My idea was(is) to take a line from the preamp and feed a low pass to sub only. This would greatly simplify things(And not send entire signal through additional curcuit). I understand the "slope" is important in blending the 2.
I never felt very deprived before (maybe don't know what I'm missing?!) but I play bass guitar and when scrutinizing recordings the bottom string just isn't there so... test tones revealed the B&W 602 start to disappear @ 45-50 hz so picking up there would seem appropriate.
Thanks everyone for the useful responses(ideas).
Old 24th April 2007, 02:11 PM   #6
Did it Himself
Your idea is right, a pre-out is the best way as long as it follows the level of the volume control.
Old 24th April 2007, 02:29 PM   #7
FastEddy's Avatar
FYI: same kind of question w/ one type solution = stereo to mono sub woofer with low pass: http://www.diyaudio.com/forums/showt...99#post1191899
Old 24th April 2007, 04:46 PM   #8
Speakerholic
Cal Weldon's Avatar
If you don't want to solder, here are a couple options from CSS. I have the B1 and am very happy. Not DIY but...
http://www.reckhorn.com/index.php?ln=en&prod=f1
http://www.reckhorn.com/index.php?ln=en&prod=b1
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 25th April 2007, 04:59 PM   #9
Marsh is offline Marsh  United Kingdom
Something like this?
http://www.bkelec.com/MODULES/asbf.htm
I learn something old every day.
Old 25th April 2007, 05:04 PM   #10
FastEddy's Avatar
Marsh: Excellent choice. This could even be a future "mod project". The open chassis = plenty of elbow room for tweaks ...
need help with low pass filter prezden Multi-Way 11 12th January 2009 08:04 AM
Low pass filter help ifrythings Subwoofers 1 24th February 2006 09:45 AM
NO low pass filter? jmar Digital Source 7 19th January 2006 12:53 PM
low pass filter crazyant Car Audio 3 15th September 2005 06:15 PM
Page generated in 0.09752 seconds (80.20% PHP - 19.80% MySQL) with 10 queries
