Old 1st April 2011, 02:02 PM   #41
Thank you
Old 13th July 2011, 12:59 PM   #42
PeterKr is offline PeterKr  Germany
Hello Ivo, I can the plans for the RT-3 to get from you?
Peter
Old 22nd August 2011, 04:13 PM   #43
Ivo is offline Ivo  Netherlands
Hello Peter,
Sorry for the very late reply, I was in the middle of moving from city to city. I have the files on a disk, which is still in a box somewhere. I will contact you when I have access to the files.
Ivo
I sehs there is no stronger breastplate, than the heart that is undainted.
Old 9th May 2013, 06:32 AM   #44
Default Larger Driver
The Klason Horn is intended to be operated as a single sub-woofer below 100 Hz. As such, the design could be scaled to match the superior performance of an 18" or 21" driver such as those made by Precision Devices (see attached PDFs).
WHG
Old 10th May 2013, 02:39 PM   #45
Hello Bill, nice to see you again. We "met" on the old Cornu forum back in the day.
Which of the versions would you scale up? It seems that the newer version of the RT1 (the old familiar Klasonhorn as was known in Europe from the Klinger loudspeakerbook) had the most extended and linear response. But, with your expertise, which one would you choose?
Old 10th May 2013, 04:28 PM   #46
Here are some simulations of various version of the Klasonhorn. In simulations of the last two versions, RT2 and RT3, the part of the horn "under the cabinet" is excluded from the simulation. The reason given is that simulation without that last segment lines up better with known response measurements. I wonder why it would have worked in iteration RT1, but not in RT2 and RT3.
RT1
RT2
RT3
Old 10th May 2013, 04:52 PM   #47
Default dimensions klason strange
i found this in an old dutch book
Old 10th May 2013, 07:54 PM   #48
Default Variant
Hi Ivo,
As part of the scaling effort, I would try to use the space in the triangular foot to house the driver. Then bifurcate the passage from there into the body of the enclosure. A curved front panel, ala Ranger's Paragon, might contribute to the enclosures aesthetics as well.
Bill
Old 10th May 2013, 07:56 PM   #49
Speakerholic
Cal Weldon's Avatar
Bill, do you know whatever happened to Daniel's forum? I went looking a while back and could not find it. I remember you being very helpful to me all those years ago.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th May 2013, 08:48 PM   #50
Hi Cal,
Cornu
Sans English version.
Bill
Strange design. Has anyone heard them? Brisso57 Multi-Way 12 28th January 2008 01:33 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
18" Folded Bass Horn Design djdan Multi-Way 11 27th October 2003 09:21 AM
Strange phase splitter design !?!? Glass_painter Tubes / Valves 6 22nd April 2003 01:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
