Old 14th April 2007, 02:30 PM   #1
Mayday is offline Mayday  Sweden
Default suitable horndesign for TangBand W8-740
My brother inlaw is going to build a subhorn to go with his Buschhorn MkII TB, but the horn should also be able to shake the furniture when watching movies. His plan is to use two TangBand W8-740C as that is what he has (he has six of them, but more than two seems overkill).
Any suggestions which horn design might fit these drivers and isn't toooo big?
Thanks!
The more you learn, the more you realize how little you know...
Mayday DIY blogg
Old 14th April 2007, 05:44 PM   #2
leadbelly's Avatar
Well, at the risk of angering the powers at be by referring to a banned member's products, have you seen these:
http://www.billfitzmaurice.com/autotuba.html
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 14th April 2007, 05:52 PM   #3
The tabletuba has been suggested to me on another forum, wonder which is the better one?
Mayday DIY blogg
Old 14th April 2007, 05:57 PM   #4
leadbelly's Avatar
Let me ask the most often asked question on this forum: "better" for what?
Old 14th April 2007, 06:05 PM   #5
It's to be integrated with 4 Buschhorn MkII TB in a hometheatre system, but still play clean and detailed bass enough to fit with two of the buschhorns for musik listening.
Mayday DIY blogg
Old 14th April 2007, 06:11 PM   #6
leadbelly's Avatar
Does it have to be a horn? I wouldn't use a horn at all for what you are decribing. The Buschorn should go pretty low on it's own, plus it's not a high SPL design, so you want a sub that goes pretty low to complement it. Bass horns in reasonable "living room" sizes are compromized in this respect, as a bass horn would have to be pretty big to go down low.
Old 14th April 2007, 06:15 PM   #7
Might be better off with a ported enclousure?
Mayday DIY blogg
Old 14th April 2007, 06:57 PM   #8
leadbelly's Avatar
Personally, I would pick ported over horn for the application you are describing if faced with only those 2 choices. I built a couple of ported W8-740's and they are fine. The problem in applying the TB to sealed and ported enclosures is the big Vas. If you are looking for something more exotic to go with a horn, consider aperiodic, ML-TL, etc. If you are handy with electronics at all, consider a Linkwitz sealed.
Old 14th April 2007, 07:02 PM   #9
Just helping my brother in law out. I'll run a few simulations with 2 of theese drivers in a ported enclosure.
Mayday DIY blogg
Old 15th April 2007, 09:19 AM   #10
hm is offline hm  Europe
hm's Avatar
Mayday,
look a few bass horns
http://www.hm-moreart.de/1.htm
BIB with 2 tangband w4-657? Mayday Full Range 2 23rd April 2007 10:53 AM
Tangband 871 and what to do with them Bylie Multi-Way 4 13th August 2004 05:51 AM
Tangband W3-871 .Can I...? Lito Full Range 4 8th June 2004 04:32 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
Anyone ever tried a tangband TL? JoeBob Multi-Way 2 30th March 2003 03:03 AM
Page generated in 0.10064 seconds (79.19% PHP - 20.81% MySQL) with 10 queries
