Is there any calculators or anything to design a bandpass box? The Driver im using is an Audiobahn AW1200Q
Fs: 31.2Hz Qts: 0.6 Qes: 0.67 Qms: 6.23 Vas: 51 Liters Vas: 1.8 Cu.Ft Le: 2.20mH Mmd: 135 Grams Xmax: +/- 12.5mm Sd: 0.045 M2 EBP: 48 Any help would be great |
#2 |
What are your design goals, car or home, associated equipment, etc....?
4th or 6th order bandpass? - (hopefully 4th with that high Qts) Try www.diysubwoofers.org For software, try WinISD beta. A naive calculation gives: 4th order bandpass fb=52.000 - tuning frequency vf=18.360 - vented volume (liters) vr=28.688 - sealed (rear) volume (liters) fh=94.647 - high frequency cutoff fl=28.569 low frequency cutoff
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
yes it will be a 4th order for car use
#4 |
| 4th order bandpass, wheel well design :) (design inside) | TWOJZ | Car Audio | 28 | 13th January 2008 02:56 PM |
| Page generated in 0.06985 seconds (68.71% PHP - 31.29% MySQL) with 10 queries |
