Audiocap Theta
I am building a set of 4pi speakers (2-way with 15in JBL2226 woofer and high frequency horn "tweeter"). If I use Audiocap Theta's for the high frequency driver, what caps do you think would work well in the woofer crossover? The cross-over frequency is somewhere around 1khz.
The crossover caps are in this configuration (woofer caps in parallel to the driver):
Do you think the Theta's will work well in this design? Thanks, David
