Factory-finished Neotech Interconnect Blowout! - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Sonic Craft
Sonic Craft Offering DIY Parts, Wire & Cable, and Mod Service.
Old 10th November 2013, 11:03 PM   #1
Default Factory-finished Neotech Interconnect Blowout!
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-4002 is a balanced Silver plated OFC conductor, PE insulation, low-loss foamed Polyethylene dielectric, and double shield via Tinned OFC braid/AL-Mylar foil shield. The NEI-4002 is terminated with Neotech's DG-202 RCA connectors.
The NEI-4002 1.5m pair is $42.50, 2m pair is $47.50, and a 3m pair is $57.50!
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-4001 is a balanced Silver plated OFC 4 conductor design, foamed PE insulation, low-loss foamed Polyethylene dielectric, and double shield via Tinned OFC braid/AL-Mylar foil shield. The NEI-4001 is terminated with Neotech's DG-202 RCA connectors.
The NEI-4001 1.5m pair is $42.50, and 2m pairs are $47.50!
Save over 50% on this excellent factory terminated interconnect! The Neotech NEI-3005 uses a UP-OCC stranded center conductor, PE insulation, low-loss foamed Polyethylene dielectric, and triple shielding via doubled OFC braid/AL-Mylar screen foil. The NEI-3005 is terminated with Neotech's DG-202 RCA connectors.
The NEI-3005 1.5m pair is $47.50, and 2m pairs are $52.50 each!
Old 18th November 2013, 11:01 AM   #2
Default What would be the shipping costs to Europe?
I'm potentially interested in a cable, but what would be the shipping costs to the Netherlands?
Kind regards,
Audionootje
Old 21st November 2013, 07:44 AM   #3
Hello,
My apologies for the very late reply!
Please create an account on our website. This will only take a few moments. Add items to your cart and proceed to check out. You will be given shipping options, and this will serve as a real time quote.
Thanks,
Jeff
Kind regards,
Audionootje
Old 21st May 2014, 04:44 PM   #4
Can you share the pF/M specs on each cable?
"It's all about the music!"
Old 21st May 2014, 06:31 PM   #5
Most of these cables are not standard stock. I have specs on a couple. Is there one in particular that you are interested in? I'm sure Neotech can provide any spec you need.
BTW, Carl, you can just contact me direct...
Old 21st May 2014, 07:00 PM   #6
Hi Jeff:
I was curious about the capacitance specs. because I made a few of my own IC's recently. That's all.
Old 20th February 2015, 08:09 PM   #7
Hi Jeff, I know it's an old add but do you still have any left for sale? Please let me know....Thanks!
Old 20th February 2015, 09:54 PM   #8
We started with a couple of pallets, so yes, we have some left. See our close out page: Close-outs, Sonic Craft
Old 20th February 2015, 11:19 PM   #9
Thanks Jeff....I'm checking it out now.
Old 21st February 2015, 06:02 PM   #10
Thank you!
Anything special about the Threshold SA/1 "Limited Edition" ? coolnose Pass Labs 5 12th February 2013 09:03 AM
Special power supply and preamplifier for STK086 adorn751 Power Supplies 4 9th December 2012 02:40 PM
soft clipping from current limited power supply unclejed613 Instruments and Amps 18 12th April 2012 12:24 AM
Special 9V supply Tarzan Power Supplies 14 17th February 2011 10:14 AM
DIY CAT5 cables finished ( plus pics of my setup ) Magnetmaz Parts 4 8th May 2003 06:08 PM
Copyright 1999-2017 diyAudio
