Go Back   Home > Forums > > >
Sonic Craft Offering DIY Parts, Wire & Cable, and Mod Service.
Old 16th April 2015, 08:54 PM   #41
stellablues is offline stellablues  United States
Jeff, in your cable idea for high-pass (2x23Ag, and 2x18Cu) which cables do you connect at the ends? do you keep the Ag together for + and CU together for - or mix 1 of each au/cu for each leg?
I'm thinking of doing an external box for my ellis 1801 and wire direct from the xover all the way up to the drivers.
Old 21st April 2015, 03:35 AM   #42
Jeff Glowacki is offline Jeff Glowacki  United States
My apologies for the very late reply. I was out of town from the 15th thru the 19th. I was too busy to check the forums I have not spent a lot of time here since we started a forum at AC.
I connect them one each for each polarity. As you said, "mix 1 of each au/cu for each leg".
Wire From Ext. Crossover to SpeakerHide this!Advertise here!
Can I use an amp power wire for speaker wire carshateme Car Audio 8 22nd September 2011 11:59 PM
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
series crossover/how to wire ?? peterpan Multi-Way 2 8th February 2004 07:08 PM
