Go Back   Home > Forums > > >
Sonic Craft Offering DIY Parts, Wire & Cable, and Mod Service.
Old 12th May 2013, 11:50 PM   #11
Danzhifi is offline Danzhifi  United States
Default Amplifier Update
I wanted to post a follow up to update the problem I'd had with this amp. Shawn inspected the board and found a couple of stressed resistors, and several more suspect resistors. After conferring with Jeff, it was determined to update all of the board level resistors with Mills and PRP types. Also updated was the DIY silver internal IC wire I'd previously used, replacing with Neotech NEI-3001.
I've had the board back, installed, biased, and breaking in now for about 2 weeks. The "crackle" in the left channel is gone. I've now got about 15 hours on it. Immediately a new level of transparency and dimensionality was apparent. A little initial brightness is mellowing and the amp is simply more of everything. Much more shimmer and decay in the highs, exceedingly natural mid band, and as punchy as any tube amplifier has a right to be. I'm WAY pleased.
My thanks to Shawn and Jeff for the world class parts and service... reasonable rates too.
Noise in left channel - modded SE 40Hide this!Advertise here!
Noise in Sony CDP-M95 left channel wheijke Digital Source 12 2nd September 2012 11:11 AM
rockford 1000a2 noise in left channel stoke Car Audio 24 12th June 2011 12:43 AM
help with some Left Channel Noise... vandalfsens Solid State 3 27th October 2010 03:57 PM
Crackling noise in left channel. fritz39 Solid State 1 20th January 2009 11:57 PM
Why is 40 volts DC comming out of my amps left channel? sound_prodigy Solid State 4 14th March 2006 05:44 PM
