Old 12th April 2007, 03:30 PM   #1
Ayne is offline Ayne  Pakistan
Default Mic PreAmplifier
I Found circuit(Attached) on net. And make it into Circuit Maker. and simulate it.
Second the result of a simulator..
It's all right???
Average output of a moving magnet Mic???
Suggestions are highly welcome..
Need Improvement???
Thanks.
Old 12th April 2007, 04:37 PM   #2
This circuit would be marginal for a cheap, high impedance dynamic mic.
The TL072 is a poor choice of devices for this application due to high input noise. An OPA2136 would be better. An OPA2228 would be better still. The electrolytic capacitors to ground (earth) in the feedback loops should be non-polar types instead of polarized.
Finally, most good dynamic mics are low impedance.
I don't understand the graph, what is it showing?
Old 12th April 2007, 07:22 PM   #3
Graph is showing "Gain VS Frequency"..
One more question.
What are the best operational amplifiers(dual supply) for Audio Preamplifiers and for MIC preamplifiers???
Thanks.
Old 12th April 2007, 08:04 PM   #4
Where did you find this circuit? It appears to be tailored to bass frequencies, there is a rolloff about 40 Hz and it shelves somewhere around 720 Hz. In that context the frequency response curve kind of makes sense...
BTW, usually frequency response is plotted on a log/log scale.
A choice of "the best op amp" depends on what the circuit demands from the op amp.
Old 13th April 2007, 03:18 AM   #5
impsick is offline impsick  United States
impsick's Avatar
try this one. i did, it works great. for moving coil or condensor.
here is mydesign...
the inductors at the input are for lower impedance sources.
the DRV134 is for balanced out.
i dont know what the best are but the Burr Brown INA217,INA163 are very good. I see in alot of gear use 5534's and 5532's.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Why do you need a preamplifier? globalweb Solid State 54 14th October 2007 04:47 PM
Preamplifier aguantesoda Solid State 24 8th September 2006 02:39 PM
Preamplifier DIY Angel Puerto Solid State 13 20th July 2005 08:53 PM
help with preamplifier skobo Solid State 9 15th July 2005 12:54 PM
OTL preamplifier filippo22 Tubes / Valves 7 14th June 2003 08:08 PM
Page generated in 0.09046 seconds (79.72% PHP - 20.28% MySQL) with 10 queries
