Old 12th April 2007, 11:14 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default Low output impedance preamp needed.
Hi all,
I need a low output impedance (about 1K) preamp stage with no gain. I prefer JFETs to use and if possible with one transistor on each channel.
Does anyone know that kind of preamp schematic?
Thanks a lot in advance.
Best regards,
Ozgur
Old 12th April 2007, 03:30 PM   #2
Ayne is offline Ayne  Pakistan
JFET input .
No gain.
Low output impedence..
I think it's all u needed.
Old 12th April 2007, 10:18 PM   #3
a source follower will give you what your after. Well nearly, the Rs <<1k0 and gain may be <1.0
It will perform better if a CCS loads the tail.
Have a look at the various schematics here and in diyhifi.org
regards Andrew T.
Old 13th April 2007, 07:18 AM   #4
Dxvideo's Avatar
Thank you Ayne.
But I am a bit confused about op-amps. Because I have tried TL072, NE5532, LM833 and LM4562 also.They all for specially audio applications. But I afraid I need a warmer sound. Because my amplifier is a lateral MOSFET Class A-AB one.
I like its sound too much but when I connect it a high output impedance device then I can hear some noise and I want to reduce that noise. This preamp is needed for that. And naturally I dont want to change its sound.
Best regards,
Ozgur
Old 13th April 2007, 07:21 AM   #5
Dxvideo's Avatar
And for Andrew;
Do you mean a circuit like that?
Best regards,
Ozgur
Old 13th April 2007, 07:44 AM   #6
No.
that's a dual complementary LTP with cascode and then a complementary follower (or is it a VAS?). =8fets, expensive in real estate and dollars.
You asked for single jFET transistor.
I suggested a follower (on it's own).
I think NUUK's site shows exactly what you are after. His update right at the end after the opamp options.
regards Andrew T.
Old 13th April 2007, 07:45 AM   #7
juma is offline juma  Serbia
juma's Avatar
No, Andrew meant a circuit like one of these :
Old 13th April 2007, 07:47 AM   #8
juma's Avatar
Sorry Andrew, you were quicker !
Old 13th April 2007, 07:49 AM   #9
Dxvideo's Avatar
Ok I see. I saw a lot of circuit like that. But somebody says
"that kind single ended circuits very prone to noise"
What do you say about that?
And also what do you say about that circuit;
Is that the same kind circuit?
Best regards,
Ozgur
Old 13th April 2007, 08:12 AM   #10
juma's Avatar
Yes it is. The lower JFET acts as a constant current source (the source resistor should be of smaller value - something like 22 Ohms). But you said that you want a circuit with one JFET.
Source follovers are not noisy, but they perform better with good power supply.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
How to calculate Tube Preamp output impedance? john65b Tubes / Valves 20 20th November 2007 02:44 PM
ARTA impedance measurements - help needed!! zobsky Multi-Way 23 3rd August 2007 06:38 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Matching a preamp to high output impedance source ainami Tubes / Valves 5 29th November 2004 04:02 PM
Page generated in 0.10108 seconds (76.58% PHP - 23.42% MySQL) with 11 queries
