Low output impedance preamp needed.
Old 13th April 2007, 08:15 AM   #11
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Ok then.
So if you compare that circuit with a 1 gain non-inverted op-amp stage, which do you prefer for a MOSAMP?
And a second question (as usual); Should I use big snubbers (4700u) plus regulators for power supply of that circuit?
Thanks again.
Best regards,
Ozgur
Low output impedance preamp needed.Hide this!Advertise here!
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
How to calculate Tube Preamp output impedance? john65b Tubes / Valves 20 20th November 2007 02:44 PM
ARTA impedance measurements - help needed!! zobsky Multi-Way 23 3rd August 2007 06:38 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Matching a preamp to high output impedance source ainami Tubes / Valves 5 29th November 2004 04:02 PM
Copyright ©1999-2017 diyAudio
