Old 11th April 2007, 11:06 PM   #1
Send a message via AIM to Spasticteapot
Default Best amplifier for newbie?
I'd like an improvement on the Gainclone, but I don't have much cash, and zero experience. I do, however, have some massive transformers and heatsinks.
Any suggestions? I'd ideally like an amplifier that can cope with my 1.5 ohm Apogee ribbons.
Old 12th April 2007, 01:42 AM   #2
djk is offline djk
djk's Avatar
Build a Krell or Leach clone.
Candidates for the Darwin Award should not read this author.
Old 12th April 2007, 02:31 AM   #3
SamL is offline SamL  New Zealand
What about the new DX amp by Destroyer X?. Look promissing with low parts count and a range of options.
http://users.tpg.com.au/users/gerskine/dxamp/
http://www.diyaudio.com/forums/showt...80#post1180680
Have fun,
Sam
Old 12th April 2007, 03:48 AM   #4
bawang is offline bawang  Malaysia
For a time-tested and DIY proven design, go with the Leach 4.5. Only problem is the relatively high component count and fiddly way to mount the temperature sensing diodes....
Old 12th April 2007, 04:40 AM   #5
Nordic is offline Nordic  South Africa
Nordic's Avatar
If all goes well, I'll be powering up a DX today.... first got to hang a door for the woman next door though....
Old 12th April 2007, 06:47 AM   #6
OzMike is offline OzMike  Australia
There was a list of reference amplifiers on a thread here somewhere recently where all the contenders were listed.
With 1.5ohms and low efficiency of the Apogee you would want about 20A current ability and about 300W for it to get up.
Mike
Old 12th April 2007, 08:12 PM   #7
Mike
Woah - 300 watts? That's a lot of power!
The Leach sounds nice, except I'd prefer an amplifier with a smaller parts count - preferably using SMD parts.
Old 12th April 2007, 10:32 PM   #8
the standard Leach v4.5 uses 2pair of 250W devices.
It will not drive 1.5ohm reactive loads reliably.
The 3pair and 5pair that Jan designed can drive low loads if the design parameters are chosen to suit that duty. The 3pair of 200W To247 only just matches the 2pair To3.
I would be tempted to try twin pairs of drivers and 6pair of 250W devices for those killer speakers.
Anything designed to be reliable with Apogees will not be cheap.
regards Andrew T.
Old 12th April 2007, 10:40 PM   #9
Yikes!
Anything more affordable out there?
Old 12th April 2007, 11:03 PM   #10
djk is offline djk
djk's Avatar
I have built the Leach with 10 pair of MJ15024/25 driving a 1 ohm ribbon with +/-80V rails.
Been running for over 15 years.
1U5 amplifier design, Newbie Speaker Dude Tubes / Valves 3 3rd May 2009 03:32 PM
How to build a very simple class D amplifier!!!For a newbie. thomgun_lc Class D 8 11th September 2005 05:13 AM
A newbie who needs help to find a good amplifier for a Shiva! simon5 Solid State 1 13th November 2004 09:17 PM
[newbie] Speakers for 450+450W amplifier Kowalski Multi-Way 1 20th January 2004 09:29 PM
Newbie DIY Amplifier Kits, suggestions drfrink24 Solid State 13 6th August 2003 02:06 PM
Page generated in 0.09668 seconds (79.36% PHP - 20.64% MySQL) with 10 queries
