Old 9th April 2007, 09:27 PM   #1
muizel is offline muizel  Netherlands
muizel's Avatar
Default Repair question Audio Research D100B
I really hope someone can give me some advise with this amp , I bought it second-hand and not in working order. At this moment I have replaced all the transistors and matched them for hfe and the amp is working again but on one channel there is quite a big dc offset about 6 volts dc. The other channel has about 5 milivolts dc wich is quiet normal. The offset goes to normal when I short the rca input, and when I lower the value off resistor R16 from 68K to 33K the high offset is also gone. Ic U2 is also replaced for a new one, as all the transistors.
My guess is that it is not in the output transistors but I cannot find the reason for this high offset.
Regards desperated René.
Old 8th February 2010, 11:20 AM   #2
dray177 is offline dray177  France
AM1 module is out I think
Be carefull, offset might be growing to 55volts
Raymond
Audio Research SP-5 recap question bacoburn Solid State 5 18th October 2009 01:48 AM
Audio Research MCP 33 reinhard Tubes / Valves 12 2nd January 2006 06:04 AM
Audio Research D 400 MK 1 Alex helge Solid State 1 21st May 2005 04:50 AM
audio research sp6/8--better than sp9? croft Parts 8 16th November 2002 01:25 AM
Audio Research Ls 2 ben goh Tubes / Valves 5 14th June 2002 07:51 PM
Page generated in 0.06896 seconds (69.34% PHP - 30.66% MySQL) with 11 queries
