#711 |
#712 |
To be safe with output transistors, especially with EF output stages I don't install them, instead I solder 100 ohm resistors from base to emitter on PNP and NPN transistors. This completes all the feedback circuits, now I measure the critical voltages like, output offset, VBE of the driver and pre-driver transistors. Once these voltages are good, I remove these resistors and install the power outputs. This saves me the output transistors and even most of the circuit if there are any gross mistakes in the assembly. Hope this helps. I've recently finished my SymAsym, almost 5 years after I bought the PCBs. But this is a wonderful amp, make my speakers sing
.Thanks,
routhun |
#713 | |
SteveA Thanks AAK, your help is greatly appreciated!! |
#714 |
Hi SteveA,
Sounds like you measured one emitter at time. You need to measure across both emitters by placing the meter's positive red probe on U3's emitter, and the neg black probe on U4's emitter. Assuming you measured 13mv on each emitter separately measuring across both emitters should give approx. zero. volts. If it is zero volts or even 13mv continue my instructions in Post #709. Make sure to turn the pot slowly, it make several turns before you see the voltage increase. Let me know how it goes. Al
Love when you can, Cry when you have to, be who you must, that's part of the plan. Last edited by AAK; 4th June 2012 at 01:06 PM. |
#715 | |
I'll get to the next step after the Twins game or sooner if they get blown out. |
#716 |
I measured voltage across the emitters on the 5 boards with all showing 0.0-0.1 mV. On 4 of the boards I was able to adjust the measurement to ~20mV with the trimpot (offset ranged from 2-26mv). On the last board the voltage stayed at 0.0mV while adjusting the trimpot (measurable voltage occurred at about 5-6 turns on boards 1-4; no change on board 5 after at least 10 turns). The BD139 on this board had an open solder joint on one leg. I replaced the part but same result, no ability to adjust voltage across emitters.
One of the 3 boards which had smoked the safety resistor showed 1.5mV across the emitters. I attempted to adjust to 20mV but within 15 seconds of powering up smoke was coming from the R5, R10 area (681R and 68.1R). |
#717 | |
Could you tell me what the lowest voltage is I could use with a symasym? How many amps does one board draw at full power? I am guessing about 1-1.5 amps but I could use some reassurance. |
#718 |
The speakers demand the current.
The amplifier tries to meet that demand by connecting the PSU to the speaker. As to minimum PSU voltage, I don't know, I have not tested the amplifier at very low voltages. In fact, I have not checked the stability of the amplifier at any supply voltages. I have accepted the design as a mature amplifier that will work as presented. Last edited by AndrewT; 11th June 2012 at 09:33 AM. |
#719 |
Anyone know what the dampingfactor of the Symasym is?
Regards Åke |
#720 | |
lineup |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| He helps with amplifier " Lineal Power" Model 652IQ | diegodgo | Car Audio | 1 | 28th October 2006 08:05 PM |
