diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Simple 2SK163 amp... (http://www.diyaudio.com/forums/solid-state/99675-simple-2sk163-amp.html)
Skorpio 8th April 2007 08:44 AM
I have 4 pcs of 2SK163 from an old Luxman amp and I would like to use them in a simple linestage with approx. 6dB gain. The problem is that I am missing data....
I have made a small test, measuring the IDSS with gate and source shortes and with 10V supply:
1: 9.39mA
2: 9.24mA
3: 9.53mA
4: 9.56mA
The first stage will be a grounded source with 2SK163 and the second stage an emitterfollower (BJT). Supply is 40V to second stage and 35V to first stage (R-C filter).
I have simulated with good results with a J109 fet with 1k source resistor and 2k4 drain resistor.
But what will be the right values with 2SK163?
Resources saved on this page: MySQL 18.75%
