Hi All,
I am new to this forum but have read many threads and have found some great info. I have an LV105 that needs some attention. I am geeting static and inconsistancy from the outputs. They may need to be cleaned. Any suggestion?
dn |
#2 |
The usual procedure is to clean all potentiometers, switches and contacts with a product called DeOxit. Also check for bad solder joints, these are quite common in 20+ years old audio gear. Cheers, G. |
#3 |
Thanks for the reply. I have never heard of DeOxit, is avalable at a retailer and is it OK to re-solder the faulty joints? I am new to servicing my own gear so I hope that you don't mind what might be really basic questions. Dave.
dn |
#4 |
Deoxit is a contact cleaner, Google for it, it's quite easy to find in Canada. yes, it's Ok to just resolder on old solder joint, use a clean soldering iron and just "wet" it with new resin-core solder from time to time. Best luck! |
#5 |
Great, thanks for the help.
Cheers, Dave.
dn |
#6 |
very old post dont know what happend but here is my 2 cents
except plenty of small cap i found leacky the driver board that layw behind the tubes is full ( full means full ) of dry soldering combination of heat and not enough ammount of soldering ( courtesy of soldering baths ) created that ... kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
| Luxman Lv-105 | Valerio | Solid State | 79 | 15th August 2011 07:36 AM |
| Luxman C 02 | Roar Malmin | Solid State | 0 | 17th May 2009 08:08 AM |
| Luxman LV-102 | hifi-valter | Solid State | 0 | 8th August 2007 01:21 PM |
| Luxman L-100 | ozaudio | Solid State | 18 | 30th October 2006 01:39 PM |
| FS: Luxman LV-105 | Ron_Phelps | Swap Meet | 1 | 16th April 2006 11:35 AM |
| Page generated in 0.07657 seconds (77.21% PHP - 22.79% MySQL) with 10 queries |
