DIY amp for bi-amped 2-way horns? DIY amp for bi-amped 2-way horns? - diyAudio
Old 4th April 2007, 11:41 PM   #1
PrestonTom is offline PrestonTom  United States
Default DIY amp for bi-amped 2-way horns?
I am gearing up for my first DIY amp project. The overall project is to bi-amp (after the crossover) a pair of high-efficiency speakers. These will be two-way horns (folded bass horn & tractrix HF). Their efficiency will be about 107 dB/watt & and will not present an impedance below about 5 Ohm.
So I do not need loads of current or power but the signal needs to be quite clean. In terms of the audio "lingo" I am after "accuracy" (especially a solid & tight bass) not "warmth and lushness".
My current candidates include 1) Leach and 2) Pass - Alpeh.
Your thoughts & wisdom are appreciated.
Old 5th April 2007, 07:17 AM   #2
with 107db/W you can manage with just a watt or two.
If you want to listen very loud then 10W to 20W.
This seems to keep you in the ClassA league, either push pull or single ended.
You do not need Leach ClassAB 120W+
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th April 2007, 02:52 PM   #3
The efficiency certainly eases the power requirements. I would be probably be going for about 20 watts (max) so Class A would be a great candidate. That is why I listed a smallish Pass design.
Since the speakers are quite revelaing (and I love an accurate sound), I was intrigued by the low TIM designs. That is why I put the Leach amp on my list.
Thanks,
-Tom
DIY amp for bi-amped 2-way horns?Hide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Where to place the amps in bi-amped/tri-amped Xicarius Everything Else 1 4th August 2004 12:13 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Bi-amped TL question Hamish Multi-Way 6 17th October 2003 07:43 PM
Copyright ©1999-2017 diyAudio
