#11 |
make shure that capacitor of filter in the input is close to regulator in some datashets is requiered a 100n with it if cap is located far away from bridge ....
also capacitors used to be located in parallel with diodes in many audio and or other application ..... makes rectifing faster but best of all try after the 100n of the output and close to regulator to add a tantalium 10 mfd this will change also a lot |
#12 | |
7815 etcs are used in a lot of digital designs remember. |
#13 |
diyAudio Moderator Emeritus
Hi, Fanuc,
The 7815 datasheet only shows ripple rejection graph until 100khz. Where you got the data for 1-3mhz from? |
#14 | |
Actually his super reg's (negating the AD797 which has probs with digital/RFi due to undegenerated inputs) have enormous loop gain at LF with a subsequent trade off at HF. This is why the venerable 7815 type design's score and are better than expected at HF. |
#15 |
Actually I don't know if a super regulator say with a jfet input like the ad8610 _without the pre reg_ (as this is unfair comparison) could beat a 7815, 7805 at psrr in the Mhz+ region.
Maybe Jan Didden could help us out on that. But i think there definately better than adjustables Lm317 types. |
#16 |
Hi, Fanuc,
From LM7815 datasheet, it show at 100khz it has only 35db ripple rejection. I don't know the data for 1-3mhz, but I think it should be lower than 35db. Is this good enough? |
#17 | |
Have you got any PSRR spec's for adjustables over >1mhz ? |
#18 |
Hi, Fanuc,
The values for LM317 at 100khz = 25dB-40dB (depending on Cadj). For LM2940 at 100khz it's 65dB (but the curve is strange, at 1Mhz it becomes 70dB) LM2940 is non-adjustable, maybe is this what you mean by comparison of adjustable and non-adjustable (where non-adjustable is better)? |
#19 |
The negative regulators are worse. 7915 don't have ripple rejection graph on its datasheet. LM2990 shows only have 20dB at 100khz.
#20 | |
Kevin |
| Low Noise 3 Leg Voltage Regulators | dsavitsk | Parts | 2 | 10th July 2007 02:49 AM |
| voltage regulators | odysseybmx414 | Chip Amps | 23 | 2nd January 2006 08:35 PM |
| voltage regulators | GAK | Tubes / Valves | 12 | 25th January 2004 04:34 PM |
| voltage regulators | NAP 160 | Digital Source | 7 | 11th August 2002 09:14 PM |
| Discrete voltage regulators. | JoeBob | Solid State | 1 | 18th March 2002 05:25 AM |
| Page generated in 0.09163 seconds (84.23% PHP - 15.77% MySQL) with 11 queries |
