Need Help and opinion on a circuit - diyAudio
Old 2nd April 2007, 06:22 PM   #1
Default Need Help and opinion on a circuit
What are the preferred parts to build this circuit?
Do I need to add the input signal into the circuit through a
summing op amp?
Thank You
Old 2nd April 2007, 07:14 PM   #2
Minion is offline Minion  Canada
That curcuit seems like a simple Tone controll curcuit with the first Opamp acting as a Unity Gain Buffer.....
I personally Build curcuits with whatever Parts that I happen to have at the time that will do the Job, so I can"t give you any specific recomendations other than the usual recomendation of useing 1% metal Film resistors and Poly/Film Caps.....
The opamps should be chosen depending on your source, a Low impedance sounce would probably be best to use a Low noise Bipolar BJT Input opamp and for a High impedance source a Fet input opamp would probably be best......
You never said what you plan on useign this curcuit for and with what sources and what other curcuitry is it going to be connected with ect???
Cheers
Old 2nd April 2007, 07:55 PM   #3
Default Thank you A BrianGT
Thank you A BrianGT Stereo kit first build
Part numbers would shue help..
Old 2nd April 2007, 11:57 PM   #4
Default What is the best opamp for this circuit?
Is there a better choice?
Old 3rd April 2007, 12:25 AM   #5
You really haven"t given enough Information for us to give you any specific recomendations....
Like what is your Supply Voltage (Bi-polar or single supply??) and the source Impedance, and if you are going to use this curcuit as a simple Tone controll or if it is also supplosed to also provide Gain also Is the LM3886 Curcuit Inverted or non-Inverted ???
There are a LOT of perameters to take into account when chooseing a curcuit topology and Opamp and what might work great in one curcuit might not work very well in another curcuit....
The way the curcuit is layed out you will need a Opamp that is Unity gain stable, you also have to take into account the speed of the Opamp(slew Rate), Offset Voltage, Voltage Noise ect....
there is no One opamp that works well everywere so you have to make your choices wizely......
Cheers
Old 3rd April 2007, 09:57 AM   #6
Default Thanks
Cheers
All good points,
"BrialGT Stereo NI 3886 chipamp kit"
http://www.chipamp.com/orders.shtml
Non-Inverting kit,
inputs: TV, DVD, CD, I havent figured out the power supply.
I have another sheme with a total input into a summing amp
to fill in the sound the filters omit. I will scan after school.
Thank You for the help, I learn more in this forum than in some
classes.
Old 3rd April 2007, 04:58 PM   #7
myhrrhleine's Avatar
Default Re: Need Help and opinion on a circuit
summing op amp?
Thank You
Personally, I'd use an OPA2134 for this.
1% resistors, good caps, etc.
voltage regulators for the supply voltage would be good too.
You could sum the inputs, then you'd have mono.
If you want stereo, build 2 circuits.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 3rd April 2007, 06:01 PM   #8
Yes, the OPA2134 would probably work well , But if you are going to use the Curcuit exactly the way it is shown (at unity Gain) then you could get away with useing a much cheaper opamp without much sacrifice in performance, Like maybe even a TL072 or even a Bipolar Opamp would also be suitable as the input impedances will probably only be in the 50kohm Range which should be OK for a Bipolar like a NE5532......
You might want to buy a few different opamps and try them in the Curcuit and choose which one you like best.......
Cheers
Old 3rd April 2007, 09:14 PM   #9
Default Thank you
Please continue, I need all the help I can get, I am new at this
if you have a betted design for a bass and treb control, please
help.. I learn as much here as in school
I would like to have something to be proud to build and i am
not too proud to ask for help.
Old 3rd April 2007, 09:36 PM   #10
Cheers
What's the point of going cheaper if one plans to buy 'a few'?
OPA2134s aren't that expensive.
Anyway, I suggested the '134 for sound, not price.
looking for opinion xxxwhezzy Car Audio 9 8th May 2008 03:53 PM
your opinion please motor_maniac18 Subwoofers 2 5th October 2005 12:59 AM
your opinion please. motor_maniac18 Car Audio 5 29th September 2005 06:45 AM
Your opinion on 813? Jax Tubes / Valves 5 16th January 2004 09:10 PM
I need your opinion.. Richard Moon Everything Else 1 11th January 2004 06:14 AM
Copyright 1999-2017 diyAudio
