#81 |
I was forced to choose between mosfets current stabilty and output drift stability. At current variant mosfets' current changes ~5-8% during warming up, and output offset changes ~40-50mV (I don't remember exactly measured values now
It is more correct to say about R13*R6, and load, and M1 transfer characteristic ratios - just to make dynamic load able to supply current to load at positive period half. Absolute R13 value is in sync with R8. As for R10 - if you have found first picture descibing the idea, you can guess I have realized some kind of hooliganism - Vgs and R10 are used to provide a (pseudo-constant) current of left bjt used as diod. This step was done in favour of simplicity, and R10 value was selected experimentally. Last edited by anli; 28th September 2009 at 03:02 PM. |
#82 |
Banned
Thanks for the information, anli. I`m just curious about the thermal stability of your arrangement. I am going to make experiments with some hard-to-tame vertical MOSFETs in a few weeks.
#83 | |
It's funny, dynamic load (M1 and around) demands on using of vertical rather lateral "for audio" mosfets: initial Vgs must be rather high to take "voltage air" for X2,X4. BTW, R10 (instead of CCS) "softens" NFB existing in the dynamic load itself - M1 transfer characteristic (dI/dV) is limited, and, as a result X2 current is mdulated by Vgs, slightly reducing dynamic load's NFB loop gain. It is, probably last "most secret place" in the schematics |
#84 |
About thermostability, more strictly - about thermoenviroment. If you have looked at a picture with showing the amplifier inside, you, probably, noticed uncommon realization details. Among others (say, frontal input RCA connectors), you can see, I have rejected common practice to mount pcb to heatsink. I'm strongly sure, low-current details (i.e. placed on PCB) must be far from heartsinks. Top and bottom case's plates perforation serv this aim also.
#85 |
Banned
Thanks for the tips. Normally, I would have proceeded a from symmetrical CFP topology (like your input stage with M2) to linearize the MOSFETs and to achieve DC stability. Single-ended input is preferable.
#86 |
I'm curious if anybody else has built this amplifier - I've not heard much about it and when I look at the goals listed in post no.1 they look very good ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| Jamo Dynamic 80 | c0nfu33io | Multi-Way | 2 | 31st July 2009 03:05 PM |
| Dynamic Range...? | Lyra | Digital Source | 40 | 2nd October 2007 11:44 PM |
| dynamic loadline | Stefanoo | Tubes / Valves | 28 | 10th January 2007 11:10 AM |
| What is Dynamic Headroom? | keyser | Solid State | 3 | 17th February 2005 07:41 PM |
| Diy dynamic driver | Vikash | Multi-Way | 77 | 22nd October 2003 07:31 PM |
| Page generated in 0.09859 seconds (77.21% PHP - 22.79% MySQL) with 11 queries |
