Old 1st April 2007, 09:29 PM   #1
Minion is offline Minion  Canada
Default Found Some 2SC367 Metal Can Toshiba Transistors...Any Info or uses for them
Hi, I was disassembleing a really old 8 Track 50w Stereo reciever amp and found 4 of these Metal Can Transistors which are numbered 2SC367.....
I have never used a Metal can transistor and I believe these must be Higher power NPN transistors or something as they were in the ouput stage of the amp, I tried to find some info on these Transistors but all I could find was in Japanese and wasn"t very helpfull.....I also found a Large number of (2sc?)C458 Transistors in a strange molded Plastic config that I have never seen before, They look like Mini regulators But I believe that they are small signal NPN Transistors.......There were also some other Transistors that looked like Metal Capacitors (germanium Transistors or maybe fets??) but I haven"t gotten arround to takeing them from the Board yet.....
Does anyone know of a Use for these Transistors and if there is a Detailed english datasheet for them....Ir if someone knows of a Schematic for an amp or any project that these would be suitable with???
Another strange thing I found was 2 small Audio Transformers, and each of these Transformers has a Piece of metal that goes over the top of the XFormer and then at the end of the Piece of metal if Folds into a thin Tube and inside this tube there is a small Metal Transistor mounted inside it.....Any Idea whats up with that??
I was maybe hopeing to the the audio transformers in Maybe a Mic preamp or mic or even at the output of an amp....They are pretty small at about 1 1/4inch squared.....
Thanx Guys.....
Old 2nd April 2007, 01:32 AM   #2
XEAGLEKEEPER's Avatar
Sorry, low power silicon toshiba
http://www.datasheets.org.uk/specsheet.php?part=2SC367
2SC458 datasheet
http://www.datasheetdirect.com/pdfs/...2528K%2529.pdf
Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 2nd April 2007, 02:35 AM   #3
Sorry....That was a Typo....They are 2SB367....
I don"t think they are Small Signal NPN"s because these are the only Transistors in the output stage and the amp puts out 25w per side, unless 2 of these can put out 25w....
anyone have info on the 2SB367????
Thanx
PS: I found a Little Info...Like they are Germanium PNP Bipolar Power transistors....But that is about it.....
Old 2nd April 2007, 05:07 AM   #4
Minion
http://www.datasheets.org.uk/specsheet.php?part=2SB367
PNP Ge 4 watt ??
Dave
Old 2nd April 2007, 05:21 PM   #5
Thanx
Old 2nd April 2007, 08:30 PM   #6
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
25Vce/1 amp max collector current/hFe~100
The Germanium types are only good for a Tj of 85C, those mini TO3s went into instinction +20years ago.
Looks like Sponge Bob has killed another thread.
WTB toshiba transistors max29 Swap Meet 0 6th December 2006 07:53 AM
www.ampslab.com , Toshiba transistors r!sc! Parts 1 1st September 2006 10:30 PM
Authentic Toshiba Transistors audio89 Parts 0 9th November 2005 04:03 PM
Toshiba XR-Z90 - Any info? Duncan Digital Source 0 15th August 2005 04:24 PM
Where to buy Sanken and Toshiba transistors weinstro Solid State 5 8th October 2003 09:58 PM
Page generated in 0.07829 seconds (81.52% PHP - 18.48% MySQL) with 10 queries
