My new mini Class A amp. - Page 6 - diyAudio
Old 11th January 2009, 10:15 PM   #51
atiq19 is offline atiq19  United Kingdom
Glen,
Do you have any spare pcbs left. I would be interested in building this state-of-the-art design. I wonder why there are few serious designs in low power level.
Thanks for sharing.
Atiq
Old 16th January 2009, 09:51 AM   #52
GK is offline GK  Australia
Same here
Hi Atiq.
I never sold or had a batch of boards made for this amp. I've only ever done that for the K10A amp.
I etched my own boards for this one. I'm part way through writing up a webpage for this amp to add to my website which will have all the details. I am very busy with work and other things at the moment, so it's taking me a while.
Glen
Old 18th January 2009, 12:16 AM   #53
OK, I've put up what I've written so far:
http://users.picknowl.com.au/~glenk/K12A.HTM
Full schematic diagram for the amp module included.
Glen
Old 18th January 2009, 12:36 AM   #54
ostripper's Avatar
Well written article and schema.. one question, what is the
purpose of D2 - D3 in schema??
OS
Old 18th January 2009, 01:37 AM   #55
OS
They are voltage clamps at the VAS bases which limit the maximum VAS current to ~20mA.
This keeps things under control when the amplifier clips.
Glen
Old 18th January 2009, 02:38 AM   #56
ostripper's Avatar
Thank you, I thought they might be ...more simple
than cordells solution as well.
As we use the same cascoded VAS , looks like a cool upgrade.
just 2 more zeners/diodes.
Would you have to change D4/5 - D6/7 for a non-EF'ed
VAS as well?? How does it work? does it clamp input of VAS before
Q24/27 go into saturation??
When it works, does it eliminate "sticking"??
OS
Old 18th January 2009, 03:04 AM   #57
OS
It eliminates one cause of sticking which is addressed in the rather different Cordell amp by the reverse-parallel diodes connected across the differential output of the LTP.
Q24 and Q27 are prevented from saturating. The cascode transistors cannot saturate either as their collector voltage is limited by the lower voltage rails provided for the triple EF output stage.
There is only one unaddressed source of sticking in this amp the pre-drivers of the triple EF are allowed to saturate. The pre-drivers are fast small signal devices and recover quickly, however. Sticking time is about 1uS and can be seen here (post 2550):
http://www.diyaudio.com/forums/showt...55#post1707755
This sticking could be eliminated with the addition of a voltage clamp at the VAS output, but I decided against this, as I wanted the greatest output swing possible from the low power output stage. 1uS sticking is a pretty minor issue.
Glen
Old 18th January 2009, 08:52 AM   #58
Glen,
Have you thought about further refinement (despite complexity) regarding potential LTP current mismatch which could be well managed by servo etc? Or it does not matter?
Thanks for your documentation on your site.
Atiq
Old 18th January 2009, 05:04 PM   #59
FaTTy is offline FaTTy  Russian Federation
Hi ,Glen
Can you show us a PCB layout for your amp? I mean gerber or similar.
Thks.
mini aleph VS gainclone VS Class D amp ecl86 Pass Labs 3 23rd June 2007 06:20 PM
M61571AFP,50W 5.1ch CLASS D mini amp projects digi01 Class D 8 8th September 2004 10:37 PM
Copyright 1999-2017 diyAudio
