Old 29th March 2007, 01:17 PM   #1
tadiam is offline tadiam  Argentina
Send a message via AIM to tadiam Send a message via MSN to tadiam Send a message via Yahoo to tadiam
Default mosfet opinion?
Diy opinion of this mosfet amplifier......
http://www.pcpaudio.com/pcpfiles/pro.../Schematic.pdf
audio
Old 29th March 2007, 06:32 PM   #2
looking quite good ;]
Old 29th March 2007, 07:00 PM   #3
Tube_Dude's Avatar
Default Re: mosfet opinion?
Hi tadiam
If you connect R 17 (22K) to ground instead the negative rail , you get much more PSRR...
Jorge
Old 29th March 2007, 09:52 PM   #4
Default ok
thanks tube dude
audio
Old 29th March 2007, 09:56 PM   #5
when up all volume have an motor boating in tha bass and one fet are more hot (no modification original circuit)
audio
Old 29th March 2007, 10:16 PM   #6
CBS240 is offline CBS240  United States
CBS240's Avatar
Do you think Q9 is saturating and causing the bias of Q5 to change? Maybe a base resistor on Q9 would help this.
All the trouble I've ever been in started out as fun......
Old 29th March 2007, 10:30 PM   #7
Is R17 even required?
Old 29th March 2007, 10:37 PM   #8
Tube_Dude's Avatar
No!
Without R17 the distortion will be lower.
But some people think that lower open loop gain is better...
Another tip , use two 1N4148 diodes as voltage reference for the CCS of the LTP, a Zenner is a very noisy reference...
Jorge
Old 30th March 2007, 02:17 AM   #9
jaycee is offline jaycee  United Kingdom
I'd say R17 is a silly idea...
Why bother with the diode in the VBE multiplier... the BD139 on the heatsink alone will be plenty. Also, don't wire the bias pot like that - an open circuit wiper will spell disaster.
I agree about the zener in the CCS, although I would use an LED (better temperature stability). 1K in the base of Q9 will also help prevent saturation in that transistor killing the CCS.
Old 30th March 2007, 03:02 AM   #10
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
For better thermal tracking and stability, you can replace BD139 with a Hexfet.
looking for opinion xxxwhezzy Car Audio 9 8th May 2008 04:53 PM
35W MOSFET Power Amp - Your Opinion binary Solid State 20 17th November 2006 12:25 PM
My N_channel Mosfet Amplifier-opinion zox2003 Solid State 9 9th April 2005 11:46 PM
opinion on MOSFET amp? AudioGeek Solid State 1 1st September 2004 05:22 PM
Elektor- MOSFET 'valvesound' amp opinion mikee12345 Solid State 0 7th August 2004 06:53 AM
Page generated in 0.10743 seconds (77.66% PHP - 22.34% MySQL) with 10 queries
