Soft start + switch on PCB
Old 18th May 2007, 04:20 AM   #21
smithy666 is offline smithy666  Australia
Hi Ian
Sorry been busy, so haven't had a chance to work out all the pricing. But the bare PCBs will be US$20 (or A$25) each + postage.
It depends upon the power rating of your amp/size of transformer. I assume both channels are being built in one case? One board would work fine in most cases for 100-200W/channel.
I will get around to pricing a kit & completed unit over the next day or so. Also toying with offering 2 options - 1 with "off the shelf" components and 1 with "high end" components (my default).
Smithy
Old 18th May 2007, 06:42 AM   #22
Loboone is offline Loboone  New Zealand
Thanks for that Smithy.
I will probably take two boards thanks.
Andrew T measured the amp at the following. Quote:
"37.05Vac into 8r just below visible clipping (=170W = 22.34dbW)
35.31Vac into 4r0 just below visible clipping(=311W = 24.94dbW)
changing from 8r to 4r reduced the maximum output voltage by 0.4dbV.
Absolutely no latch up as it comes out of clipping and no sign of instability at 3W & 300W into resistive load"
So I will probably run the amps as mono blocks but in the same case. Separate power supplies.
I assume that I will be able to source all the components over the ditch here as you will probably source them from the same suppliers as I have access to.
Ian
Old 18th May 2007, 06:50 AM   #23
Ian
Yes, they use standard parts that you can access easily enough. If you get stuck on any, I can help out. I'll get a schematic and parts list finished to supply with the boards. I forgot to say I have 3 available at the moment with more on the way.
Smithy
Old 18th May 2007, 07:01 AM   #24
Any chance of getting two of you soon then?
Ian
Old 18th May 2007, 07:05 AM   #25
Ian
Drop me an e-mail atomicnirvana (at) gmail.com and we can sort out payment etc. Should be able to send off Monday.
Smithy
Old 21st May 2007, 09:28 AM   #26
Finally got around to working our pricing, as follows:
Bare PCB (double sided, plated, solder mask & silkscreen) with schematic, parts list and overlays US$20 or AUD$25 per board
PCB and all on board components (high quality resistors, caps, semis etc) with schematic, parts list and overlays US$85 or AUD$105
Completed and tested US$105 or AUD$130
Above pricing excludes delivery - please e-mail for shipping cost (atomicnirvana@gmail.com)
Any questions, please let me know.
Old 23rd May 2007, 05:23 AM   #27
Dante is offline Dante  Canada
One unit for me. How can we proceed for payment ?
Old 23rd May 2007, 05:32 AM   #28
Hi Dante
You can pay by Paypal do you want the bare PCB, kit or built?
Drop me an e-mail at atomicnirvana@gmail.com and I'll give you details + shipping depending upon what option you want.
Old 24th May 2007, 12:17 AM   #29
Cloth Ears is offline Cloth Ears  Australia
Cloth Ears's Avatar
Originally posted by smithy666
Hi Dante
atomicnirvana(at)gmail.com and I'll give you details + shipping depending upon what option you want.
Chris,
You might want to ask the moderators to remove the direct reference to your email address in the previous post (spam alert!)
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 4th September 2007, 05:33 AM   #30
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default can you send me your last letter
i think its goes to junk mail and delete
thank you for your help
Soft start + switch on PCBHide this!Advertise here!
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 01:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
