humming Harman Kardon 330B
Old 26th February 2011, 01:23 AM   #11
wkjagt is offline wkjagt  Canada
Wow, I just got back to this post after four years. I see the date of the last post is the day my son was born and the receiver was forgotten. Now, four years later, I dug up this receiver from the garage and will hopefully finish this project.
Old 26th February 2011, 04:07 AM   #12
stratus46 is offline stratus46  United States
I repaired a good number of those back in the '70s. IIRC I used 2N6488 power transistors as the originals had a tendency to tear an internal lead when warming up making the device go open. It would come back when it cooled off. The 6488s never came back to haunt me. Digikey still has them for $1.16 in single units.
G
Old 26th February 2011, 11:02 AM   #13
soundmeister is offline soundmeister  Australia
Download the schematic.
You have Pre-Out and Main-In sockets....replace the links with a 2RCA-2RCA cable and swap left/rights to determine if preamp stage or power amp stage is at fault.
Let me know the answer before you do anything more.
Dave.
Old 26th February 2011, 06:31 PM   #14
Hi Dave,
swapping left and right doesn't change anything: the hum is still coming from the left. Does that mean the problem is in the power amp stage?
Old 26th February 2011, 06:32 PM   #15
Oh, I didn't test with speakers, but with head phones. Would that make a difference?
Old 26th February 2011, 11:59 PM   #16
Ok, tested with speakers: same result.
Old 27th February 2011, 01:09 AM   #17
Yes, you have a crook output stage.
Try swapping C514 and C614 (35V 47uF).
Also try swapping F901 and F902 - fuses can develop internal dry solder joint.
Also did you mention oozing from under capacitors ?.
It is quite normal for larger caps to be glued to the board using 'contact glue'.
In time this can turn choc brown/black and become conductive - best to lift the caps and remove it, but this is likely not the fault cause.
Try this and let me know.
Dave.
Old 6th March 2011, 03:38 AM   #18
Went to the biggest electronics store in Montreal, and they didn't have the right capacitors. Does anyone know of a good online store where I could buy these sort of things?
Old 6th March 2011, 04:00 AM   #19
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
the previous link
http://manuals.harman.com/hk/Service...K330b%20sm.pdf
is a 404 (not found)
HK's new web site only has the owner's manual available
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 8th March 2011, 02:06 AM   #20
I have the pdf. I can send it to you if you pm me your email address.
humming Harman Kardon 330BHide this!Advertise here!
Harman Kardon 730 cedus Solid State 5 17th March 2009 09:02 AM
Harmon Kardon 330B repair laboitenoire Solid State 4 1st April 2007 08:58 AM
For Sale Harman Kardon T60 Turntable / Harman Kardon Cd491 Cassette Deck electric blue Swap Meet 1 25th August 2006 11:36 PM
Harman-Kardon PM 665 sangram Solid State 1 17th May 2006 06:32 AM
Harman-Kardon 330B schematic needed Algar_emi Solid State 15 12th March 2005 01:06 AM
