Hello friends, here I leave east scheme you, to see that it seems to you.
Greetings
Greetings
How is the common mode operation? Is the voltage source feeding the differentials and mirror regulated? I would lower the -rail to the differentials a little more and cascode the second differential(VAS). Or even both of them Oh yeah, if those rails are not regulated, I would add CCS's and fix that mirror as danville suggested. Or use a Wilson, cascode or swap mirror.
