Congratulations to Charles on Stereophile's excellent review of what by all appearances looks to be (ahem, and is no doubt sonically) an excellent product!
Tom |
#2 |
MX-R mono amplifier
The Ayre MX-R mono amplifier takes a bold new approach to amplifier design. Its unique monocoque architecture joins the chassis and the heat sink into a single elegant structure for unparalleled mechanical integrity. The dual-transformer linear power supply effortlessly drives the most demanding loudspeakers. Our exclusive EquiLock technology enhances the zero-feedback, fully-balanced circuitry for an unprecedented level of clarity and resolution. Breathing new life and vitality into your favorite compositions, the Ayre MX-R will change the way you listen to music. Features/Specifications | Manual -------------------------------------------------------------------------------- Features Zero-feedback, fully-balanced discrete circuitry Linear analog power supply Ayre's exclusive Equilock circuit Ultra-low loss circuit board material Custom developed audio-grade resistors Proprietary polystyrene capacitors ThermalTraktm transistors for real time optimal biasing Ayre Conditioner (patent pending) power line RFI filter AyreLink communication system Specifications Power Output 300 watts per channel continuous into 8 ohms 600 watts per channel continuous into 4 ohms Gain 26 dB Input Impedance 2 Mohm balanced (1 Mohm per phase) Frequency Response DC - 250 kHz Power Consumption 45 watts in standby mode 120 watts in operating mode, no signal Dimensions 11" W x 18.75" D x 3.75" H (28cm x 48cm x 9.5cm) Weight 52 pounds 23 kg |
#3 |
Mr Hansen definitely is first in line for the dustfree amp award.
Looks like Sponge Bob has killed another thread. |
#4 |
Now all we need is a schematic.
No Just kidding. Having heard the prior Ayre amplifiers i am sure this is a fine piece of equipment. Michael |
#5 |
Do you think the amp is self-dusting? That's gotta be the future for hifi.
Tom |
#6 |
Yah, nice amp. $16,500 a set and one blew up during the 2-ohm test. It blew two of four fuses, but when the two fuses were replaced, they blew again – dead amp.
There were also the obvious problems associated with zero-feedback amps. Besides weird lumps in the frequency response, but also greatly increasing distortion with decreased load impedance. Analog linear power supply? Couldn’t their sales department/BS-artists do better than that? Leave it to Stereophile – even though the amp blew, they tinkled all over it. Sure, gorgeous heatsink/chassis, compact design, clean layout, but $16.5K? No thanks.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
#7 |
I'm told a special brush to clean the fins and holes between the fins is complementary.
(acused of having a sense of humor) Anyone ever trying to copy the MX-R has my deepest sympathy.
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Charcoal "Supreem" hi-density foam "enclosure" | IG81 | Multi-Way | 0 | 23rd April 2009 01:34 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.09058 seconds (78.50% PHP - 21.50% MySQL) with 11 queries |
