Old 19th March 2007, 08:56 PM   #1
Default philips FA-951
The other day I came across this amplifier which is in 900-series design. All analog inputs play OK but when I tried to connect thru digital Ins (several of them as well as out for Aux, DCC etc.) it was no go. There was no sound either thru phones or speakers although the "Digital" indicator on the front panel lighted up. Any ideas?
Old 19th March 2007, 09:21 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
In case the manual could help you out, here it is:
http://www.usersmanualguide.com/phil...o__other/page8
/Hugo
Old 20th March 2007, 06:24 PM   #3
Thanks a lot, Netlist, for the heads-up. Added the site to my favorites. Found the manual there for my CD-880. Now it's clear that the amp doesn't play thru digital, it only uses it for recording. Funny, though, because a CD player can be connected directly to a digital recorder. Maybe the point is to control the recording, but to do this you should connect the player to analog inputs. A little bit complicated. I meant to use the amp as an outboard DAC but alas. I wonder is it possible to make digital recording of LPs. Doubt that strongly but I'll try.
Old 20th March 2007, 06:30 PM   #4
Netlist's Avatar
Glad to help.
As I'm not that much into digital, I can't help here but your best bet is indeed to experiment.
I use the PC to do vinyl transfer.
/Hugo
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CD 960 @lf Digital Source 13 16th October 2006 06:08 PM
Philips cd 931/00 jimraft Parts 1 12th November 2005 05:19 PM
Page generated in 0.07806 seconds (74.92% PHP - 25.08% MySQL) with 10 queries
