For 35A rectifiers, what is maximum without heatsink
Old 17th March 2007, 10:17 AM   #1
geminni is offline geminni  Serbia
Default For 35A rectifiers, what is maximum without heatsink
I couldn't find how many ampers can survive rectifier without heatsink.
I have downloaded datasheet for it but there was nothing about it.
Can i use this 35A for 2x200 amplifier rated at 8 ohm?
Old 17th March 2007, 11:03 AM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
You will only draw max current on Power On.
While playing the current are reduced to app. 10A for 8 Ohm speakers at full power.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 17th March 2007, 11:07 AM   #3
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hard to tell without more info but an easy solution for cooling a rectifier bridge is to mount it on the chassis. In most cases that will be enough unless we are talking big classA amplifiers.
/Hugo
Old 17th March 2007, 07:45 PM   #4
Thanks for the graph, ACD!
So, by the graph i relize that my rectifier, 35A, can be pushed to deliver some 31 amps without any trouble on 40C summer temp
Ok, mounted a small heatsink ofcourse
Other thing about this i want to ask. I have made the amplifier 2x40w runing 6 ohm speaker. Transformer is 2x20V with 4 Amps, for stereo. Rectifier is 35A and does not have heatsink. Is this safe for rectifier? Only 4 amps and no heatsink?
Old 17th March 2007, 08:12 PM   #5
sawreyrw is offline sawreyrw  United States
The current handling capability depends on the thermal resistance for junction to ambient. I have no idea what you are using, but a Rth of 20 to 30 degrees C/watt wouldn't surprise me. So you could dissapate only 3 to 4 watts without overheating.
Old 17th March 2007, 09:28 PM   #6
Jan Dupont's Avatar
Please see other diy-constructions here at the forum....
Many "low power" amps (up to 80-100W) have the diode bridge fitted on the PCB without any heatsinking
Above that, I would recommend just to fitt the diode bridge to the chassis to be save
Old 18th March 2007, 07:15 AM   #7
batee is offline batee  United States
batee's Avatar
I tried a GBPC3506 at 25A and no sink (not even chassis), ambient temp was about 35F. It cracked along one side, but continued to function.
Bryan
Old 18th March 2007, 07:22 AM   #8
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
it's easier to drill one hole and fit one screw than to write two posts
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th March 2007, 07:29 AM   #9
Jan Dupont's Avatar
It has to be fitted someway anyway, so just attach it to bottom or back plate of the chassis
Old 18th March 2007, 12:34 PM   #10
Ok, thanks!
For 35A rectifiers, what is maximum without heatsinkHide this!Advertise here!
HornResponse Maximum SPL bubblersound Subwoofers 3 21st June 2009 04:07 PM
Heatsink for two STK4050V in maximum power ElectroPower Chip Amps 2 24th July 2007 03:27 PM
Maximum current in VAS stage rtarbell Solid State 5 16th July 2006 12:08 PM
Tubes and maximum ratings rtarbell Tubes / Valves 4 29th November 2005 09:09 AM
Maximum Capacitance before Pffffft? G-Daddy Solid State 4 19th March 2002 09:17 AM
Copyright ©1999-2017 diyAudio
