Mod - Upgrading opamps in a yamaha av receiver
If these are surface-mount, you may not be able to do anything (for mechanical reasons).
I found other side of PCB and all caps are not SMD :) So can change the caps to better one.
post DAC section-
Today l could investigate Yamaha 667 and found some details.
DAC section uses some nichicon VR(M) 10uf, some SMG(regular and KZ) and one fine gold series near DAC chip.Is that SMG from United chemi con capacitor?
Closer look-
I cant see ceramic caps.:confused:
Power caps are only 6800uf-
Now will changing to better nichicon (from VRM to other series) can improve it much?
please share your views.
Thanks.
